  • Guests: 32
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Wireless christmas tree?
BigBad
Mon Dec 06 2010, 02:42AM Print
I was toying with the idea of driving my entire christmas tree with AC current (at about a megahertz), and then hanging on several individual lights, I probably would be using a christmas bauble as a capacitor in series with an inductor so it rings, and then using it to drive an LED light or two. I worked out that the capacitance would be a few tens of pf, so I would probably need fairly high voltage (well over 100v) on the capacitor, but the capacitance is tiny, so it should be safe(?) Probably low volts on the tree itself though.
Not sure if it would work though; has anyone tried doing this kind of thing with the electrical characteristics of a live tree? It's kinda the thing that people must have tried before. I want mainly near field (obviously) but in practice does it radiate unacceptably?
Is there any massive gotcha that anyone knows about before I try it?
Mon Dec 06 2010, 10:38AM
the field needed to light up an LED wouldn't be that high, but you would run into problems with RF interference to nearby devices.
seems a very inefficient way to light LEDs, due to inverse square losses...
-A
BigBad
Mon Dec 06 2010, 03:30PM
Inverse square law shouldn't be a problem, because I would use the tree as one conductor (and capacitively couple to Earth as the other).
Pinky's Brain
Mon Dec 06 2010, 06:15PM
A LC circuit isn't going to help you AFAICS.
AFAICS the purely resistive part of the impedance from the bark (where you're power supply is attached) to the leaves (where your lights are attached) is going to be much larger than the resistance directly to ground through the tree. For every mW of light you are going to be putting a hundred into the tree most likely.
BigBad
Mon Dec 06 2010, 06:31PM
I was planning on putting a probe directly into the tree to contact the sap (or maybe experimenting with driving it via the roots, putting a probe in the soil). The point is that sap is conductive. (Theoretically I could put a ferrite around the tree and drive it wirelessly by that).
To couple to the light I could do the same thing, or use close range capacitive coupling.
But I'll think about it, and maybe try it and see.
The idea of the resonance is to avoid having a return wire.
Bjørn
Mon Dec 06 2010, 08:34PM
It is an interesting idea, but a combustible conductor is a really bad idea.
BigBad
Mon Dec 06 2010, 08:59PM
The biggest problem I've found so far is that the resistance of the tree is probably higher than I'd hoped (~1k ohm). That might scupper it, since I'd have to make the voltage on the tree itself quite high, which might make it unsafe.
Also the inductors are looking annoyingly heavy/bulky.
Ash Small
Mon Dec 06 2010, 09:42PM
This is a very interesting concept. I hope you can find a solution, however, if you decide it can't be done, maybe you should consider replacing the star on the top of the tree with a tesla coil (or similar device).
This should light up all the lights, and more!!
(just an idea)
Mattski
Tue Dec 07 2010, 12:44AM
It's kind of a silly idea, but this would be pretty cool to see. Have you actually measured this 1kOhm resistance? That isn't so bad, if each LED in parallel has a 1kOhm resistance to your source at the base of the trunk that only drops 20V from the source to the LED. Obviously you can't pack the LEDs in too densely though. How have you estimated the capacitance of a metalized spherical ornament? Just using a random estimate of 1pF you would need ~25mH inductance, which is pretty big. You probably would want to put a chicken wire ground plane beneath the tree, or even around it though it won't do much for the aesthetics.
Obviously if you do this experiment indoors you should keep a very close eye on it as well as a ready fire extinguisher or two. Christmas tree fires can be very dangerous.
BigBad
Tue Dec 07 2010, 01:36AM
I'm not worried about the bursting-into-flames angle, the currents would be very low, so the I^R is negligible.
I'm much more interested in shock hazards. Still, it's currents that kill, not voltage, and we can presumably arrange to have high voltage/very low currents (think static discharge).
And yeah, the inductances are looking really awkward.
Incidentally, capacitance of a sphere in free space is just 4Pi E0 R, Where E0 is 8.85e-12 and R is the radius in metres (but the proximity of the tree will probably reduce that by a factor of 2 or 4 or something.)
