  • Guests: 93
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Homemade geiger counter/radiation detector problem
hsieh
Sat Dec 04 2010, 01:51PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I saw this webside and decided to experiment with homemade radiation detectors.I built the " Experimenter's Ionization Chamber" circuit in this webside.
I build this circuit.But I get 9V on my multimeter instead of several millivolts. I use BC517 transistor(I can't find MPSW45) and I haven't connect the ion chamber yet.What's wrong with my circuit?
Thanks
Matt Edwards
Sat Dec 04 2010, 02:59PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Could you post a photograph of your circuit for comparison with the origion circuit?
hsieh
Sat Dec 04 2010, 04:31PM
Oidium45 wrote ...
My circuit
I use 1k resistor and BC517 transister.The circuit is the same.
1291480299 1412 FT102335 Dscn7760
Sat Dec 04 2010, 05:23PM
EDIT: transistor specified is in fact a darlington with high enough gain to work.. sorry for the confusion!!
have you double checked the pinout etc
also don't forget that unless it is right next to an intense source it won't do anything.
-A
hsieh
Sun Dec 05 2010, 05:33AM
Conundrum wrote ...
didn't they specify a darlington transistor? i vaguely recall this circuit needs either one or several conventional transistors in series, as it needs >10000 gain to detect activity from a lantern mantle etc.
-A
BC517 datasheet
According the datasheet,BC517 has gain >30000.So that's why I choose it.
Or can I connect several general propose transistors together ?
