  • Guests: 80
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Welder rectifier
HazzWold 1993
Sat Dec 04 2010, 09:51AM Print
Hey i pulled this rectifier from an old welder i found but have no idea how to wire it, also i cant find any specs on the diodes due to them being blank so i don't know how many amps i could push through it safely. seeings as i wanted to use it on a rewound MOT for electrolysis. so any tips or help anyone can give is appreciated!
also on the back it says - CF-4/1/140
Matt Edwards
Sat Dec 04 2010, 03:13PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
I would disassemble it and use the components to make a smaller rectifier. It must be a bit old. Looks homemade. I am almost convinced that those connecting posts are drive straps from a pressure plate assembly for an automotive clutch.
radiotech
Sun Dec 05 2010, 06:24AM
From what you are holding in your hand I would say thats
a 25 Amp 100 Volt bridge.
HazzWold 1993
Sun Dec 05 2010, 08:31AM
only 25? thats kind of saddening. oh well ill just keep an eye out for an alternator.
Electroholic
Sun Dec 05 2010, 09:58AM
If im not mistaken, the 4 black button looking thingies are the actual diodes. I've seen diodes in the same package in the 25 to 50A range.
HazzWold 1993
Sun Dec 05 2010, 10:00AM
yeah they are the diodes. thanks
radiotech
Sun Dec 05 2010, 08:06PM
When you salvage things keep a note
of the size of the wires that it was attached to.
Why that rectifier looks that way might be it
was a furnished replacement for a selanium rectifier
that was no longer made. The unit would be the
general shape only much larger. By making it
the way you found it, all the old wiring would fit.
