  • Guests: 39
cockroft walton multiplier question
Patric
Thu Dec 02 2010, 09:26PM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
I have 6 diodes 12 kVolt and 6 capacitors 1.6 kV. I assume I can make a cockroft walton 6 X multiplier, but what is the maximum ac I can put on the entrance?
Please forgive my ignorance.
Daedronus
Thu Dec 02 2010, 09:46PM
1/2 of your capacitor rating...with some safety margin.
ScotchTapeLord
Thu Dec 02 2010, 09:52PM
Remember that the peak of the AC has to be half the capacitor's rating. So assuming 1.6kV is your capacitor's maximum working voltage, your maximum input would have to be under (1600/2)/(1.41) = 567V.
If the 1.6kV rating is an AC rating, then that changes things...
EDIT: 567V is the AC RMS voltage
Thu Dec 02 2010, 10:00PM
Patric wrote ...
The capacitors must be rated at a minimum of twice the peak . So with your caps, you can have a peak input voltage of 800V or about 570V RMS.
Patric
Fri Dec 03 2010, 09:02AM
Thanks! I was not sure, now I am! I will use 500V ac.
Same with diodes? What is the max ac tension by a 1n4007?
Patric
Mon Dec 06 2010, 04:13PM
AleSeg
Tue Dec 07 2010, 10:09AM
AleSeg Registered Member #2727 Joined: Tue Mar 09 2010, 02:39PM
The diode 1n4007 can stand 1kV, and you need the same voltage in the diodes than the voltage you have for the capacitors . You need two in series of these diodes for synthetize each diode in your multiplier.
Cheers!
Patric
Wed Dec 08 2010, 11:57AM
Thank you again! May the Force be with you!
