  • Guests: 51
Primary woes
Meatball
Wed Dec 01 2010, 04:04AM Print
Meatball Registered Member #2401 Joined: Mon Sept 28 2009, 04:25PM
Finally getting my own ZVS put together.
Considering that my inductor is 47uH, my psu is 25VDC and that I have #14 solid copper wire available, should I use it to wind my 4+4 primary along with those extra 3+3 turns?
Or should I find some stranded wire since its a heck of a lot easier to work with? Center tapping stranded wire comes with its own challenges though...
From reading these threads after searching:
I have come to no reasonable conclusions on my own.
Also, any reason why it would be wise to add another 470 ohm resistor in series with those already in the circuit- right away before testing?
Thanks guys, you've always been quite helpful!
-TT
Matt Edwards
Wed Dec 01 2010, 04:40AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
I don't have any experience with stranded and have heard bad things but maybe someone here has tried it. Anyway, you should be fine with 14awg solid if that is what is available. I have used 18awg with a 50v input.
As for the 4x4 and 3x3 I assume you are referring to this schematic? Link2
If so, it is a great circuit as is with little to no changes necessary unless you wish to run a higher input voltage.
Make sure that your power supply can handle the needed current draw if you plan to use the flyback to draw arcs. I have gotten a few 6v lantern batteries so hot that the posts melted the plastic on the battery.
Oh, and if you need a good parts list let me know.
Adam Munich
Wed Dec 01 2010, 05:40AM
I replaced my "variable resistors" with 470 ohm 3w resistors and the ZVS works great even at 36V. So no, I'd say you don't need to add more resistors.
As for your primary, 18AWG works fine so I see no problem with 14. You can also get litz wire from computer monitors; the inductors on there are full of it. Litz wire is the stuff you want for high freq AC.
quicksilver
Wed Dec 01 2010, 04:00PM
IF you have a decent electronics store there are various size "taps" for simply cutting into shielded/insulated wire. They are OFTEN sold at places that have electrical contractors products and solve a whole lot of problems. they are great for everything from a center tap like you're talking about to a Primary on a TC. They are little plastic and steel snap-together items and come in wide variety of different sizes. They make a project very neat and tidy.
Meatball
Thu Dec 02 2010, 02:14AM
Note: Stay away from lantern batteries..
I'll stick to my ATX PSUs in series..
I think I'll go find some 18 awg since it will be easier to work with than that nasty 14 awg.
Yes, I should have specified that I was going the Mazilli-2 circuit.
Too bad I don't have any old monitors around. I actually got this flyback from a local TV repair shop- not a TV.
Thanks for the wire tap suggestion, I'll go back to the shack and see what I can find.
I went ahead and just assembled it tonight. I tried to keep things symmetrical so I could keep things straight.
156204 1522327540959 1317690211 31221388 5033615 N
148567 1522327700963 1317690211 31221389 1202299 N
155154 1522327940969 1317690211 31221390 2967126 N
Cute little heatsinks, aren't they? I just want to gobble them up./
Wish me luck as I'm making a first test run tomorrow!
[Edit: Image size]
Matt Edwards
Thu Dec 02 2010, 05:04AM
Not to sound negative but I give you about a 30 second run until you kill the fets with such small heatsinks. Good luck! Otherwise looks good!
Meatball
Thu Dec 02 2010, 05:08AM
Really? I always hear how the FETs run cool. I see other people use larger heatsinks, and then say that they're overkill.
How much larger should I go?
I can always mount a nice fan or a blower next to the circuit. The thing fits in my pocket.
Adam Munich
Thu Dec 02 2010, 05:24AM
If you don't use a fan then you'll have to go big. If you do use a fan you can make things small and compact. For example;
1291267425 2893 FT102001 Dsc08398
This can run at 36V for about 20 seconds w/o a fan, with a fan nearly 5 minutes. The flyback would melt before the fets die of heat stroke.
ZakWolf
Thu Dec 02 2010, 08:37AM
i have slightly bigger heat sinks and i power my circuit with 10 amps at 15 volts and they never get hot
Adam Munich
Thu Dec 02 2010, 08:45AM
Oh they will when you pump 36V at 44A through them like I do.
