  • Guests: 59
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
Question...
Adam Munich
Mon Nov 29 2010, 06:54AM Print
Anyone have any clue as to why the ground electrode in a flyback arc gets much hotter than the one at potential? I would think the one at +HV would get much hotter due to electrons bombarding it, but no...
It is + HV too, both my kilovoltmeter and a neon lamp said so.
Ash Small
Mon Nov 29 2010, 08:11AM
Are you sure you're looking at this the right way?
The HV lead on a flyback is negative, assuming it has diodes. the ground pin is at a positive potential compared to the HV lead.
Electrons flow from the HV lead to the ground pin.
(Or have I misunderstood you?)
EDIT: THE ABOVE COMMENT REGARDING POLARITY OF A FLYBACK IS INCORRECT, i WAS GETTING MIXED UP WITH SOMETHING ELSE.
radiotech
Mon Nov 29 2010, 08:33AM
Charges flow in the arc. But what moves is ions. Which way the
charges move depends on the polarity of the current.
The current is the same in the ground wire as the hot wire. The
temperature depends on the mass of the conductor and the
resistance of the coupling between the metalic state and the plasma.
Unless you strike the arc in a vacuum, do you think any free electrons will get far?
Welding technology would be a good place to seek answers, or
even arc light designs have diffences between + and - terminals.
Do Faraday's laws of electrolysis apply to current flowing in DC plasmas? Do charges flow at the same rate as ions? What is heavier, cations or anions.
Ash Small
Mon Nov 29 2010, 08:46AM
Radiotech, electrons generally travel a lot faster than ions in plasma, do to the considerable difference in mass. They are both subjected to the same electrostatic force, assuming the ion is +1 charge.
You don't actually get much ion flow as such in an arc, compared to electron flow, though (unless you are welding). You will get ions in the plasma as electrons ionise the air molecules. The heat is generated by the electrons essentially losing kinetic energy when they enter the positive electrode.
Adam Munich
Mon Nov 29 2010, 11:37AM
No, the flyback I'm using definitely puts out a positive high voltage. Neon glow lamps don't lie.
Freitsu
Mon Nov 29 2010, 11:57AM
Freitsu Registered Member #3147 Joined: Sun Aug 29 2010, 10:53AM
Just to make things clearer, neonlights glow on the negative electrode. But surely you knew that. wink
Antonio
Mon Nov 29 2010, 12:24PM
Flyback transformers are used to charge the screen of CRTs with positive charge, and so the output is invariably positive.
Ash Small
Mon Nov 29 2010, 12:52PM
Antonio, I think you must be correct, I must be getting mixed up with something else.
Sorry if I've supplied incorrect information.
Mon Nov 29 2010, 01:48PM
A modern LOPT ("flyback") has two high voltage outputs, one of typically 1.2kV which supplies a positive charge to the focusing anode though which the electron beam must travel, and the EHT output which typically provides 20 - 30kV both to the accelerating anode, and to the conductive internal coating of the tube - often aquadag - whose job is to to reduce picture distortion by catching the secondary emission electrons released from the screen by the impact of the electron beam.
The reason that these CRT electrodes are always positively charged, is because the electrons they attract and control are negative.
Adam Munich
Mon Nov 29 2010, 08:34PM
Yeah I knew flybacks put out +HV, but this still doesn't answer the question.
If electron bombardment doesn't heat the ground wire, what does? The difference in heating is quite substantial too. Iron nails melt when they are connected to ground, but the high voltage wire doesn't even get hot...
