  • Guests: 89
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Transformer Science Fair Project
H8erade
Sun Nov 28 2010, 11:25PM Print
H8erade Registered Member #3451 Joined: Sun Nov 28 2010, 11:13PM
Hello, everyone. I'm doing a school science fair project involving transformers (I'd rather not share the specifics). I know that I need an AC source, but that's not all - I also need to be able to vary the frequency of the alternating current. I've been looking into function generators as a means to achieve this... Is this the right way to go? Would I simply be able to operate a step-up, standard, iron core power transformer using the output from a function generator? I would appreciate any help you can offer.
radiotech
Sun Nov 28 2010, 11:38PM
You sure can. Use a solid state amplifier with about 50
watts output and connect a 6.3-120 volt transformer
with the 6.3 volt windings to the 4 ohm output. This
will give you 120 VAC from about 30-1000 Hz with
about 20 watts to play with if you use a 5 amp
transformer.
This is how I powered resonant circuit demonstations with
small lamps for years.
H8erade
Fri Dec 03 2010, 10:35PM
Thank you for the quick reply, and I'm sorry for delaying mine. I've been really busy with school work. Anyway, I understand now, so thanks for your help.
ubuntupokemoninc
Mon Dec 06 2010, 01:55AM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
uh oh, i'm smell something not working here, i built 4 transformers before i actually got 1 to work and that was an a boit that i rebuilt with the core, what are you using for a core and how mane turns of wire are you using for the primary because with low frequency ac you have to have LOTS of turns on the primary, and an insane amount of wire on the secondary for step up, it won't work other wise, just use high frequency then you can have like 5 turns on the primary and like 200 on the secondary for step up
