  • Guests: 58
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Need help with a half bridge.
Daedronus
Sat Nov 27 2010, 12:36PM Print
I have been trying to make a half bridge smps for some time...so far I got it to work nicely open loop, that is, no feedback control at all, just a manually selected duty cycle from 0 to 49% per phase.
This was with a DC blocking capacitor in series with the transformer, to prevent flux walking.
After this I tried to add pulse by pulse peak current limit, with a smps controller IC, the DC blocking capacitor was also removed....since pulse by pulse is not supposed to work with it.
The peak current limit worked, but it got the two capacitors that provide the VCC/2 divider completely unbalanced, one fully charged to VCC and one completely drained.
As far as I understand this was to be expected, there is a fairchildsemi's paper that describes this, and a solution:
Problem is, even with the balancing winding the two capacitors still get unbalanced...
I'm also thinking, would a full bridge be easier to get working with peak current limit? since there are no capacitors in series that can get unbalanced....
cjk2
Sat Nov 27 2010, 05:44PM
I did a current mode half bridge that worked. I had the same problem you did at first, then I added the balance winding with a turn through the current transformer and the problem went away. Take a look at the schematic here.
Daedronus
Mon Nov 29 2010, 02:39PM
Hmm, for C11 and C12 in your schematic I was using far larger capacitors, 660uF, electrolytic.
I replaced them with smaller 2.2uF, non electrolytic, doesn't seem to work much better. They don't get fully unbalanced, instead now they get almost completely discharged then charged on each cycle.
I can do do pretty much any connection variant with the balance winding, with or without the turn trough the curent transformer, and it doesn't seem to make any difference.
It does seem to reduce a bit power if connected while the current limit is not connected.
My controller IC is a uc3843, with a flip flop and a AND gate on the output to make the two signals for the high and low mosfets.
The Current transformer output is rectified, filtered a little bit, passes trough a simple resistive divider so I can play around with the level, then fed to the current sense pin.
I'm beginning to hate this half bridge thing..Next week end I think I'll try to make a full bridge and try again with peak current control.
