  • Guests: 89
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
IR detectors
Luca
Wed Nov 24 2010, 09:49AM Print
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Hi all,
I need to make a thermometer using IR detectors. I am looking for detectors like pyroelectric or thermopiles but I think that the latter are the most suitable...
I dont need anything really precise, something with an accuracy of +/-1°C would be enough. The important point is that it should be something as cheap as possible (it's not for an amatorial project, it is for industrial production...)
I have searched on internet but it seems quite difficult to find this kind of devices, I have found a component on RS but it's quite expensive, and I have seen that PerkinElmer makes thermopile detectrors but, agian, I am worried about the price...
Do you know manufacturers that produce this kind of decvices?
Dy you have any other suggestions? (other kind of detectors, etc...)
Regards,
Luca
Wed Nov 24 2010, 06:37PM
What is the temperature range that you need to measure?
Luca
Wed Nov 24 2010, 09:24PM
Sulaiman wrote ...
The subject will be between ambient temp and +150°C, while the sensor will be between -25 and +75°C
Luca
lightlinked
Thu Nov 25 2010, 01:37AM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
this melexis sensor is available from a few manufacturers on breakout boards.
Bjørn
Thu Nov 25 2010, 08:34AM
For a cheap non contact sensor that is very accurate and in some cases impossible. The accuracy would depened a lot on the type of surface of the target and other variables.
You can get cheap PIR sensors for less than $2 but you need the type with a single element. The ones with two elements in antiparallel are only suitable for detecting changes in temperature. To get your required accuracy under all conditions the circuit required would be complex. There are ready made chips for the purpose but they may fail to reach your accuracy target.
Here is an article with some ideas: Link2
There must be countless patents you can study.
Luca
Tue Nov 30 2010, 10:02AM
Bjørn wrote ...
We have found thermopile sensors from Heimansensors with the precision of 0.1°C for less than 2 euros (price for very large volumes). There are also complete modules, with the co-packaged ASIC for signal conditioning and A/D conversion, but these are much more expensive (x10...)
If you think to some modern medical thermometers (ear-thermometer), they are based on the same technology (IR), they have at least 0.1°C precision and they are on the market for few tens of euros. So, it is obvious that the sensor itself must cost only few euros.
Regards,
Luca
Bored Chemist
Tue Nov 30 2010, 04:24PM
Not many people's ears range from ambient to 150C.
0.1C is easier if you know that the material you are looking at is always the same stuff - i.e. skin and therefore always has the same emissivity and it is practically always 30C to 40 C.
Having the sensor maintained at room temp helps too.
Tue Nov 30 2010, 09:42PM
Bored Chemist wrote ...
... easier if you know that the material you are looking at is always the same stuff - i.e. skin and therefore always has the same emissivity and it is practically always 30C to 40 C.
There's a lot of valid "green" media buzz lately, about painting dark roofs white to keep houses cooler in summer time. But it's a joke when a contractor escorts a reporter to a sunny work site, points his IR thermometer at some unpainted black roofing, then a freshly painted white section, and claims instant 30 degree reduction. No allowance for different emissivity in the long wave IR (or evaporative cooling of wet paint, for that matter).
Wed Dec 01 2010, 11:05AM
What is the point of this? You can go to a store and buy a non-contact IR thermometer, so why does the original poster want to make one?
