  • Guests: 31
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
A TL494 based HV generator
Kabelnazs
Tue Nov 23 2010, 04:23PM Print
Kabelnazs Registered Member #3436 Joined: Tue Nov 23 2010, 04:12PM
HI
My newest project is a HV generator on this TL494 (woner chip :) ), i have the shematics for generator, and drivers (its will be i hope a Halfbridge generator ), but the problem is the power part of the generator , i have this wonderful IGBT`s [HGTG11N120CND] :
but i dont now ho to run them (without a grey smoke :D ) , mb some have a shematic for the H-bridge, the power for the bridge i think i make 300-400VDC (similar to pc power supply)
Kabelnazs
Tue Nov 23 2010, 09:10PM
Hmm :D i have this circuit, my first Mk1 version, i hope its will work, but mb some one have assembled something like this and can me help a bit rolleyes
First time a H-Bridge gen, all other was only a boost converters or cheap 555 stuff :D
1290546620 3436 FT101258 Tl494
Kabelnazs
Wed Nov 24 2010, 08:49PM
Hello
Is anybody hear? :)
/silence
I have one more question , may be some answers it in this year :)
Ho long can be the wires (leads) of the GDT? I will split my circuit in two parts one with generator and the drivers , the other will be the power part with GDT, IGBT`S, trafo ~ 15v for all electronics and all other stuff. My idea is connect the outgoing signal from generator with the GDT with screaned cable length about 10-15cm (dependent on case for PS)
Antonio
Thu Nov 25 2010, 12:26AM
Not a serious problem. The frequency will not be so high, and anyway there are the huge input capacitances of the IGBTs as load for the transformer.
Kabelnazs
Thu Nov 25 2010, 10:32AM
Thanks!
This Weekend (too much work in working days, cannot go to my Lab :((( ) then i will try to make the first version of my new HV PS :)
Im thinking now about current protection for the power section, im add some current transfo 1:20 to control the output current and protect IGBT`s i have one idea i will post it later:)
Kabelnazs
Sat Nov 27 2010, 05:14PM
It`s Live, Live :)
Generator works well, now drive`s and the power part
There is the experimental PCB [pic1] and the signals on my scope [pic2]
1290878061 3436 FT101258 Attls087
1290878061 3436 FT101258 Attls090
