  • Guests: 26
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
How do you control your power for HV?
Tue Nov 23 2010, 05:04AM Print
I would like to submit a simple poll asking members how they control input power to their HV devices. I am curious if you use a variac, smps, or other device. Please state what the method, what you use it for (tesla, heater, crusher) and how much voltage/amperage you deliver with the method. Thanks.
Tue Nov 23 2010, 07:15AM
i use a variac to power a 244 VA NST @ 90-140 VAC and about 4.5 amps at 120vac input, i use it for DeSeversky Lifter testing.
UPDATE: my variac goes from 0-140vac, at up to 12 amps, though the label says "1200W max do not exceed."
Tue Nov 23 2010, 07:51AM
I use a 12A 230VAC Variac to all my coils, large as small, it was fitted with a 10A fuse that my DRSSTC took out after running at 2500W for 5 minutes.
I also have 10A single phase variac, 6A three phased variac and 25A three phased variac at my disposal.
I have been lookinf for smaller 1-4A variacs that are more handy, but variac are sturdy, will take a beating for short periods and I never had one fail on me :)
Tue Nov 23 2010, 10:39AM
I use a variac that goes to 11, for that extra push over the cliff. smile
Seriously, I have two variacs, a 2A and a 10A, plus a couple of 1:1 isolating transformers, some plate transformers from tube equipment, a small NST, a large NST, a MOT, a 4x voltage multiplier for use with the MOT to provide 10kV DC @ 0.1A, and two 1kW SMPS, one 0-150V and one 0-600V.
At work I have access to the HV lab with various Brandenburg SMPS up to 100kV DC, a 110kV Marx generator, and a 100kV, 10kVA test transformer with computer control (ironically, through a motor-driven variac) and datalogging. This is all quite modest by HV lab standards, but it's still fun smile
My last few SSTCs all use phase angle control with SCRs. It allows crude voltage control for low-power tests, but most importantly, a soft start to charge the big cap bank without blowing fuses and breakers.
I used the variac for prototyping, and installed the SCR unit once I was happy with the rest of the electronics. I have built them up to 30A @ 240V AC input, using a 90A SCR brick as a doubler.
Tue Nov 23 2010, 07:16PM
I got a current & voltage regulated flyback driver so I got some control. but it's NOT suitable for anything with sparks, electrostatic stuff only.
I have tried a electrostatic motor on it, I have also used it for experiments on CRT's; and I also use it to find broken bulbs in the x-mas lights.
The later one.. I just listen for bulbs that go "snap snap snap" or "bzzzz"
I plan to build 1-3 extra flyback drivers, but I will need some help in circuit design, tuning, testing, calibration so that's stuff for the future.
I got a 8A variac (with added soft-start from a microwave, fuse and power indicator) that I use for low voltage stuff.
(below 260V AC that is, mains is 230V 50Hz here).
I have used it some for SMPS testing e.t.c.
And I also use it to control heating when we melt led for casting of fishing weights.
