  • Guests: 36
  • Members: 1
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
Eirik's flyback driver
HazzWold 1993
Mon Nov 22 2010, 12:06AM Print
In this circuit Link2
If i wanted to run the logic section alone on twelve volt. would cutting out the 7812 and putting 12v+ into where the collector of the 2N3904 joins up the top and then say 50v into the top of the flybacks primary. would that work? i just want to run this at a higher voltage. thanks
Mon Nov 22 2010, 12:34AM
Yea that'd work.
HazzWold 1993
Mon Nov 22 2010, 12:38AM
cheers.
tritium
Mon Nov 22 2010, 05:31PM
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
7812 is 24-30 volt max, maybe 40V but I am sure not 50V, and there are spikes, so you will blow your voltage regulator,
maybe a LM117 is better fot this, google the datasheets for it, they give plenty information.
cheers wink
HazzWold 1993
Mon Nov 22 2010, 08:40PM
tritium wrote ...
cheers wink
Thanks but what i mean is i was cutting the regulator out all together.
