  • Guests: 35
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
X-Ray Spectrometer
1 2 3 4
Sat Nov 20 2010, 02:21PM Print
UNDER CONSTRUCTION
X-Ray Spectrometer
a winter's project
SAFETY FIRST
Ray Ray Tube Hazards
1290262018 543 FT0 Wear Your Dosemeter
1290262047 543 FT0 Dosimeters 001
From top to bottom:
Harwell generic LCD dosimeter with user set alarm level.
Alrad Gammatell II LED dosimeter
Golden Oldie Quartz Fibre Dosimeter
1290267254 543 FT0 Lead Flashing Roll
18kg Lead sheet roll to BS EN 12588 Code 4 (1.8mm)
1290267285 543 FT0 Lead In Other Forms 004
Lead in other useful forms:
Lead ingots, three to the kilo
Lead foil
Lead self-adhesive tape
UNDER CONSTRUCTION
Sun Nov 21 2010, 08:04PM
X-Ray Spectrometer
X-Ray Sources - Svetlana BS-5
UNDER CONSTRUCTION
Ray Tube Bs5 Cu And W
The Svetlana BS-5 is a low power end-window transmission-target X-ray tube designed for very close anode-to-sample coupling by means of an integral collimator. The tube is available in two anode flavours, copper and tungsten, but are identical in all other respects.
A transmission target means that X-rays produced at the focal spot must pass through the target - which needs must be thin - to exit the tube .
Ray Tube Bs5  W Engraving
The made-by-hand engineering is evident when we see that the tungsten anode type has been inscribed as a W with a carbide pencil.
Ray Tube Bs5 Cu Engraving
And Cu for copper on this one.
Ray Tube Bs5 End Window
The beryllium end window through which the collimated X-ray beam emerges has a diameter of 2.5mm.
Ray Tube Bs5 Base Pins Oil Hole 1
This hole in the base allows the dielectric oil to enter, and to expand and contract without damaging pressure disequilibrium.
1290369351 543 FT0 Bs5 Filament V V I Ratings
Filament current increases with filament voltage reaching its maximum design limit of 3.9A at 1.5V, and is one of the ways in which
the anode current of an X-ray tube may be altered without changing the anode voltage and output photon energy.
1290369380 543 FT0 Bs5 Ia V Va Power Graph
Target transmission X-ray tubes will quickly fail if they are overdriven. This graph of anode voltage against anode current shows the
maximum current in µA permitted across the tube's working voltage range from 10kV - 30kV.
Unlike diagnostic Xray tubes, which typically operate in the millisecond regime, and have a very layed back duty cycle to chill out between exposures, analytic X-ray tubes must be able to run continuously for long periods if needs be, and require attention to detail in their cooling.
1290369508 543 FT0 Bs5 Grid Bias Versus Ia Graphs
The BS-5 is a true triode, by which I mean that the anode current can be controlled to cut-off by a negative bias on the grid. The top graph shows the anode current in µA across a range of negative grid bias with 30kV on the anode, and filament current 3.9A.
The lower of the graphs above shows anode current variation for a given grid bias range when there is 10kV on the anode, and filament current is again 3.9A.
Ray Spectrum
Copper anode: characteristic X-ray spectrum.
Ray Spectrum
Tungsten anode: characteristic X-ray spectrum.
UNDER CONSTRUCTION
Mon Nov 22 2010, 03:30PM
X-Ray Spectrometer
X-Ray Sources - Svetlana BH-4
UNDER CONSTRUCTION
1290439304 543 FT0 Bh4 Ag And Ge Both Choice A
The Svetlana BH-4 series of low power target transmission X-ray tubes feature Au, Ag, and Ge anodes. I've laid my hands
on the silver and germanium types for this project.
1290439334 543 FT0 Bh4 Ag Stamp Choice B
The Ag mark hand-stamped onto the anode block of one....
1290439367 543 FT0 Bh4 Ge Stamp Choice C
And the Germanium stamp on the other.
1290439407 543 FT0 Bh4 End Window Choice D
The end window is at the tip of a short collimator emerging from the conical copper anode block.
1290439441 543 FT0 Bh4 End Window Choice E
The beryllium exit window in the centre circle has a diameter of 3mm.
1290439481 543 FT0 Bh4 Base Choice F
The three pin phenolic resin base has a large oil hole to flood the innards with dielectric fluid.
1290439513 543 FT0 Bh4 Data Sheet Pin Out Diagram Choice G
The focusing cup marked "3" in the diagram keeps the electrons on the straight and narrow as they fly towards the anode.
It is kept at negative potential relative to the filament.
1290439549 543 FT0 Bh4 Data Sheet Graphs H
The graph at the top shows the filament current for different values of filament voltage.
The lower graph shows the maximum current in µA allowable for anode voltages up to 50kV to keep the tube within its safe dissipation limit.
1290439597 543 FT0 Bh4 Germanium Spectrum I
Germanium anode: X-ray spectrum
The strong Ge Kα line at 9.9keV is an excellent marker for ~10keV.
1290439624 543 FT0 Bh4 Silver Spectrum J
Silver anode: X-ray spectrum.
Silver is my absolute favourite X-ray anode because the strong Kα line at 22.2keV - the left-hand spike in the highlighted region - is relatively easy to isolate as a nearly monochromatic X-ray beam.
UNDER CONSTRUCTION
Tue Nov 23 2010, 12:51PM
X-Ray Spectrometer
Proportional Counter Tubes and PSU
UNDER CONSTRUCTION
1290516182 543 FT0 Proportional Counter Tubes General View A
The disintegrating protective foam is typical of Soviet era packaging after prolonged storage.
Nonetheless, the Russian manufacturer, Bourevestnik of St. Petersburg, waxes lyrical about the prowess of these particular tubes:
"Gas-filled proportional counters of SI series were applied in space projects focused on X-radiation of the Sun and the stars, the Venus surface matter, on orbital spacecrafts ("Lunohod-1", "Vega-1", "Vega-2" stations, "Astron", "Salut-4" space observatories, Satellites Series "Kosmos" and "Interkosmos")."
So we are keeping good company. smile
1290516210 543 FT0 Proportional Counter Tubes Two Tubes With Ruler B
Each tube has two beryllium windows - one on either side - to allow both entry and escape.
1290516232 543 FT0 Proportional Graph C
1290516251 543 FT0 Proportional Counter Tubes End Label 1 D
Type: SI-11R-1
Fill gas: so called "P-10 gas" - Ar 90% CH4 10%
Working Voltage: 1650V
Energy range: 5-15keV
Max Counting Speed: 10E5 cps
Shielded Count Rate: 40 cpm
1290516302 543 FT0 Proportional Counter Tubes End Label 2 E
Type: SI-11R-2
Fill gas: Kr 90% CH4 10%
Working Voltage: 1700V
Energy range 15 - 40keV
Shielded Count Rate: 300 cpm
1290516347 543 FT0 Proportional Counter Tubes End Label 4a F
Type: SI-11R-4
Fill Gas: Ne 90% CH4 10%
Working Voltage: 1250V
Energy Range: 2 - 5keV
Shielded Count Rate: 20 cpm
1290516397 543 FT0 Bertan 3kv Psu Crop G
UNDER CONSTRUCTION
Fri Nov 26 2010, 02:36PM
UNDER CONSTRUCTION
CALIBRATION TOOLS
X-Ray Photometer
Ray Photometer Face Plate A
Ray Photometer Back Panel B
Back panel: SHV socket for PMT EHT supply.
BNC PMT signal input.
Mains input, mains fuse.
Remote control cable socket.
Ray Photometer Pmt Head C
Photometer NaI(Th) scintillator/PMT head
NE Technology Farmer Dosemeter model 2570/1
1280504660 543 FT0 Farmer Dosemeter General View Portable With  Handle Up
Here is my NE Technology Farmer Dosemeter model 2570/1 which can automatically compute dosage v. time calculations.
It is completely portable, and runs off two standard 1.5V D cells inserted into a holder in the back panel.
1280504660 543 FT0 Farmer Dosemeter Front Panel Overview Final
The ionization chamber polarising voltage is nominally 250V (251V shown), while the sign of the polarising voltage may be reversed by a switch on the back panel, which also offers switchable voltage division options of V/2, V/4, and V/8.
The great joy of the instrument is that when standard Famer-type chamber sizes are selected - 0.03 cc, 0.6 cc, or 600 cc, the instrument will function as a direct reading dosemeter.
1280504801 543 FT0 Farmer Dosemeter Front Detail Lcd Display Final
Using the keypad, one can select a dose - say 1 Gy - and press the start button, and the instrument will trip the X-ray source via a back panel port when that dose has been delivered.
Use of free-air ionisation chambers is made possible by the correction keys - T for temperature, P for pressure in mBars, and CF for the chamber correction factor, the most troublesome of the corrections. Happily, parts of the chamber correction aggregate are available pre-computed in tabular form for 10 keV, 25 keV, 50 keV and above, thanks to the BNIP.
1280504842 543 FT0 Farmer Dosemeter Lcd Display Fine Detail Final
The instrument can produce results for both Absorbed Dose in Gy, and Exposure in C/kg.
1280504980 543 FT0 Farmer Dosemeter Rear Panel Overview Final
The back panel is home to the battery locker, which houses 2 x 1.5V D Cells. A serial port can directly feed results to a printer, as well as tripping a relay to start and stop an X-ray or other source at a given dose or time.
The dessicator cartridge may be inspected for colour change, and replaced with a fresh one if necessary, via the perspex plate at right.
1280505085 543 FT0 Farmer Dosemeter Rear Panel Polished Detail Of Switches Final
UNDER CONSTRUCTION
Sat Nov 27 2010, 10:57PM
UNDER CONSTRUCTION
X-Ray Tube 25kV 1mA Variable Dual PSU
PSU Overwiew
A dual +ve/-ve independently controllable dual PSU - effectively two separate PSUs - allows me to power both grounded anode and grounded cathode tubes up to 25kV, or to supply up to 50kV across a common mode load without needing to have more than 25kV worth of insulation-to-ground.
The high voltage transformer primaries are powered by two GE 220V 1A Variacs, allowing stepless indendent change of both EHTpositive and negative rails.
The transformer outputs both feed 2-stage full-wave Cockcroft & Walton voltage multipliers. The transformers Vpk being 11kV, the full-wave 2-stage multiplier would have an output of about 40kV at 1mA, but as this would mean exceeding the safe working voltage of the 16kV capacitors, I will set the spindle stop on the Variacs to limit the output voltage to 25kV. I work on the basis that the capacitor rating must be double the peak voltage for safe operation, i.e. 8kV for the 16kV capacitors I have available.
Multiplied X-ray tube anode volts also means multiplied shielding costs, and as this setup working under reduced power can still supply
50kV across a tube if needs be, I see no reason to buy more costly capacitors. Were I to need more milliamps, my minimalist approach to voltage multiplication at 50Hz would become unreasonable - like Henning Umland's baroque X-ray machine that takes up a good part of his cellar:
At the output of the full-wave multiplier, I have added what is both a low pass 16Hz pi filter, and a safety resistor, to keep the maximum possible short-circuit current through the diodes to 25mA - 5mA below their maximum current rating.
1290898280 543 FT0 Ignition Transformers Ruler 2
I was lucky to buy four of these excellent transformers brand new on ebay for £16 (18.94 EUR) because no one else bid for them.
They came with Cofi logo three pin mains connectors.
Many ignition transformers are rated only for intermittent operation, but these beauties are designed for continuous use.
What a shame that Cofi's 17kV peak model can only run in 4 minute bursts without getting all hot and bothered.
1290907779 543 FT0 Cofi Data Sheet
1290898320 543 FT0 Ignition Transformers With Mains Leads 1
1290898345 543 FT0 Variacs 1
1290898390 543 FT0 Variacs 2
1290898420 543 FT0 Variacs 3
UNDER CONSTRUCTION
Adam Munich
Sat Nov 27 2010, 11:11PM
Fancy collection of parts. How will this be designed?
Sun Nov 28 2010, 01:04AM
Grenadier wrote ...
How will it be designed? By intuition, with occasional calculation to sharpen the image in my mind.
All is 'under construction,' so previous posts - in fact, episodes - are all subject to further development, modification, clarification, exegesis, and the like, until the Fat Lady sings, as they say! smile
Sun Nov 28 2010, 11:05AM
UNDER CONSTRUCTION
X-RAY TUBE PSU FULL-WAVE C&W SECTION
One of Two
1290941624 543 FT0 Voltage Multiplier Section
The 20nF capacitors shown in the first stage are formed from two 10nF in parallel.
Using 16kV rated capacitors is not ideal. It limits my maximum peak C&W input voltage to 8kV, but was all that I could find
in my stack. An 8kV input will still produce about 30kV at the full-wave C&W output, which is more than enough for the low power
analytical X-rays tubes I have to hand - indeed the maximum anode voltage permitted for BS-5.
1290946373 543 FT0 Capacitors10nf 16kv All Nine With Tape Measure Choice B
Each of the two C&W multipliers in the PSU requires nine capacitors.
1290941692 543 FT0 Capacitors10nf 16kv Single
1290941727 543 FT0 Diode Rectifiers 30kv 30ma Crop Choice
30kV 30mA diode rectifiers
UNDER CONSTRUCTION
IntraWinding
Sun Nov 28 2010, 11:06AM
Will you use a crystal of some type as a diffraction grating, or have I got the wrong end of the stick?
