  • Guests: 35
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
WaveRider (62)
Njubster (34)
10/30 Aragorn (41)
10/31 Tor (40)
10/31 RussT (67)
445nM radiation hazards?
dmg
Thu Nov 18 2010, 05:09AM Print
Aside from the usual eye/retina damage possibility.
I wondered what are some distinct hazards of laser light that other light sources do not pose?
so far I only see harm in it from vision and burn hazards, and I would like to know if anyone else here knows what other ill effects could result from exposure to this radiation (to body/skin mostly, as eyes are covered).
Thank you.
1290056982 2628 FT0 Laze
Bjørn
Thu Nov 18 2010, 09:08AM
Light at wavelengts above 400 nm are generally not considered to be a problem in normal cases.
Search for "spectral effectiveness" to find quite a lot of information.
Thu Nov 18 2010, 09:21PM
according to some articles wavelengths shorter than 450nm can cause skin damage similar to UVA with much lower effectiveness.
the main concern I'd have is that due to the far smaller focal spot the damage can extend quite deep into the skin compared with a longer wavelength (i.e. red) and potentially cause quite a serious burn even at low power.
Others have mentioned the tendency of the 445nm diodes to "jump" in power unexpectedly when near their threshold with only a milliamp more current, resulting in a hazardous beam if reflected off a nearby object such as an alignment tool etc.
see laserpointerforums for more information..
-A
