  • Guests: 49
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Hybrid batteries tease big energy capacity while charging in seconds
Adam Munich
Wed Nov 17 2010, 12:19AM Print
Ioxus Inc. is an up and comer in the energy storage industry that has plans this Monday to announce a new hybrid storage device that it hopes will radically alter batteries used in the auto, medical, and consumer electronics industries. The teased product is said to be roughly the size of a typical C-cell battery and combines the fast charge / discharge benefits of ultracapacitors with the impressive energy-to-weight ratio of a lithium-ion electrode. As a result, Ioxus says the hybrid devices can store more than double the energy of traditional ultracapacitors and charge in a matter of seconds. The catch is that the hybrids have shorter life spans of 20,000 cycles compared to millions of cycles for typical ultracapacitors. We're also taking this with a grain of skepticism until these claims are proven in the field. Some brief digging though did unearth an article written by MIT researchers and published in Scientific American last year that discusses the possible benefits of supercharging lithium-ion cells -- which is encouraging.
The first iteration could be used to power a host of devices like off-the-grid lighting or power tools. Use in larger systems like the regenerative breaks of electric cars however won't be possible until the second generation arrives -- which the CEO pegged as sometime in the first quarter of next year.
1289604328
Source
Sweet. Sounds like this technology will have a massive impact on the electric car industry one day, and the portable electronics industry. If they have such a low resistance that they can charge in seconds, that means they could discharge quickly too. For those who like cap banks, 200*2.3V 800F caps in series = 26.45 kilojoules if my math is correct.
Wed Nov 17 2010, 12:53AM
Sweet. Sounds like this will have a MASSIVE impact on the electric car industry, and the portable electronics industry. If they have such a low resistance that they can charge in seconds, that means they could discharge quickly too. For those who like cap banks, 200*2.3V 800F caps in series = 26.45 kilojoules if my math is correct.
I figured a value 16.0 times greater: 423 kJ (2116 J per capacitor) . anybody else want to vote?
If I'm right, then the bank of 200 could ideally accelerate 1 metric ton to 29 m/s = 105 kph = 65 mph.
The same total energy could be had from a dozen C-size alkaline batteries, if you were willing to draw it over a period of hours.
Ultracapacitor banks are already in service in hybrid city buses, with one charge/discharge cycle at every bus stop. They fill a niche between rechargeable batteries (much higher energy density) and conventional capacitors (much higher power density).
Adam Munich
Wed Nov 17 2010, 12:59AM
Oh well I did ((1/800) * 200) *.5 * (200*2.3)^2. It doesn't matter right now though.
I know it's not a lot of total energy, but this is only the first generation of these things. If they are as good as they say and don't be a dick with the patents like mazda did with the wankel, hardcore research could be put into the chemistry and in a decade they could possibly start replacing li-ions.
Wed Nov 17 2010, 01:03AM
I see the math problem.
You figured 1/4 farad at 460 volts; s/b 4 farads. The 800 belongs on top and 200 on the bottom.
We agree that the technology could be good for lots of practical things,
other than just getting money from investors.
Adam Munich
Wed Nov 17 2010, 01:08AM
Oops, lol I assumed they were 1 volt each.
In // 200 caps would supply 627kJ, or 1.07 cans of coke. We really need to find a way to convert sugar to electricity.
Bjørn
Wed Nov 17 2010, 01:52AM
The datasheet says that they have less power density then the cheap lithium battery I have on my desk. So they seem even less useful than normal ultra capacitors.
Pinky's Brain
Wed Nov 17 2010, 02:09AM
We have a really good way to turn sugar into electricity, turn it into ethanol and pour it into a combustion engine with a generator attached ... the problem is the pollution.
Lets hope DEFCs are perfected in the near future.
Adam Munich
Wed Nov 17 2010, 02:20AM
I was thinking of a more direct means, something directly chemical instead of mechanical. There's a problem with your plan and it's the internal combustion engine. It's a wasteful flawed design that wastes a lot of energy as heat light and sound. Not only that, but fermentation takes a lot of time and money, especially on the huge industrial scale that bio fuel would need.
Chris Russell
Wed Nov 17 2010, 06:36AM
Chris Russell ... not Russel!
Fermentation takes time and money, and distillation takes even more time and money. I'm not sure if this is still the case as I haven't researched the matter lately, but not too long ago it took more energy (not counting sunlight) to grow, harvest, mash, ferment, and distill than one can get out of the ethanol in the end.
That said, we humans are pretty good about getting energy out of sugar, since we can skip everything after grow and harvest. I've seen some interesting preliminary research into powering devices like laptops, cell phones, etc simply using our own blood sugar. Presumably at some point in the distant future, we will be able to have a personal power port installed. Then we really can convert that can of coke directly into electricity.
At any rate, these hybrid capacitors seem like an interesting step in a different direction. Only time will tell if that direction turns out to be useful. As Bjorn rightly pointed out, these aren't terribly useful just yet.
Wed Nov 17 2010, 11:48AM
Chris Russell wrote ...
The problem is just that we use far more energy than what we eat. 1kW per person is considered some sort of reasonable target for world power consumption. I exceed it a little myself, Americans exceed it by about a factor of 4. But the consumption of food energy is only a couple of hundred watts per person.
Effectively we each have an army of about 10 slaves, and they all have to be fed. Currently they eat oil, but once the oil runs out, they will have to be fed some other way, or scrapped. The world production of all the kinds of bio-stuff combined is not enough.
I ride a bike to work, so my transport is already powered by sugar, cakes, pasta, bread, pizza and so on. smile
