  • Guests: 32
Resistor Suggestion for Cap Bank
1 2 3 4  last
Sir Fixalot
Tue Nov 16 2010, 02:53AM Print
Sir Fixalot Registered Member #2810 Joined: Sat Apr 17 2010, 07:17PM
Hokay, I have 8 350 v 2900 uf lytics, and I want to arrange them in 4 sub-banks of 2 in series (each sub-bank will be 700v, and 1450 Uf). Of course I wanna include some safety so none of the caps overcharge the others, so im going to put a resistor across each cap. Any of these Oughta be sufficient, right?
or is the resistance too high? Any help appreciated.
ScotchTapeLord
Tue Nov 16 2010, 04:39AM
Why not 1/8 Watt, 1 Meg resistors? They're all you need and won't waste power.
Unless your capacitors have terrible, terrible leakage... in which case they are probably not safe to use at all...
Tue Nov 16 2010, 08:09AM
ScotchTapeLord wrote ...
Aside from the safety bleeder function, I think the goal of the resistors is to balance the voltages in a series string of C's (since you guys think it's silly to charge to anything less than 100% of rated voltage).
Without R's, the steady state voltage ratio is determined by the matching of leakage currents -- but 1 megohm R's are too weak to matter much with datasheet-tolerable leakage currents in 2900 uF 350 V Al-can capacitors, which are in the milliamp range.
More important than leakage matching, the voltage ratio during rapid charging depends on the matching of capacitance values (remember the individual units are probably rated -10%, + 50% tolerance).
I think a conservative design wants balancing resistors that waste a fair fraction (10% ?) of the charger output power -- unless you selectively match the capacitors.
My recommendation, which also saves resistors: Form all 8 capacitors in parallel for a while, then measure them individually & make two groups of four to dividing total C in half, as closely as possible.
Each group of 4 is wired in parallel, with one bleed resistor. The two groups are connected in series.
A secondary benefit of matching C values: equal voltage change during a pulse discharge shot, which happens too fast for bleeder R's to matter. To avoid reversing the voltage on the half-bank with smaller C.
ScotchTapeLord
Tue Nov 16 2010, 02:07PM
Oh, thanks for that. I never realized the leakage was so bad in those capacitors.
Sir Fixalot
Tue Nov 16 2010, 02:10PM
Klugesmith wrote ...
That's the main reason I wanted the resistors; so the caps are as balanced as possible when charged.
Jasonr
Wed Nov 17 2010, 02:19AM
Jasonr Registered Member #167 Joined: Mon Feb 13 2006, 06:41PM
BE CAREFUL!!!! it will not really matter the leakage of the caps. it is more the body style of the resistors
i=v/r and then p=iv those little 1/8 guys will be smoking hot!
plus if memory serves 1/8 watt is only good to 150volts?
Jason
Saz43
Wed Nov 17 2010, 03:12AM
Jasonr wrote ...
Jason
I've used 1/8 watts up to 400V with no problem.
ScotchTapeLord
Wed Nov 17 2010, 03:50AM
Hm? Obviously a 1 M ohm, 1/8 watt resistor can tolerate 350V.
P = V^2/R or I^2*R
using V^2/R
.125 Watts = V^2/(10^6 ohms)
V^2 = 125000 Volts^2
V = 353.553 Volts
having 350V across it is the only way to get the wattage that high! Just do math to determine what wattage you need for your application.
But if your capacitors have leakage resistances that are lower than a few M ohms, then you'll have to use a lower rated resistor which will require a higher wattage rating.
Sir Fixalot
Wed Nov 17 2010, 06:21AM
The reason I don't want to do that is to keep the ESR Low-I would much rather do sub-banks of 2 in series.
Sir Fixalot
Wed Nov 17 2010, 07:50AM
I really really appreciate all this help, but this still doesn't answer my question: what do yall think about the resistors I suggested? are they fitting? overkill?
1 2 3 4  last
