  • Guests: 47
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
TL494 PWM supply help 0-50v 5A
Matt Edwards
Mon Nov 15 2010, 06:43PM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Could someone look this circuit over and tell me if it sucks? Also, I am open to suggestions if someone has a better low voltage circuit. Thanks!
Mon Nov 15 2010, 07:09PM
looks ok, although maybe overkill for a simple SMPS.
i might have a go at building one..
regards, -A
"Botheuurgh" said Pooh, as he developed backscatter induced radiation sickness...
Electra
Mon Nov 15 2010, 09:41PM
Looks to be from the early era of switch mode design, no reason to suggest why it would still not work though.
Was trying to figure out what the little circuit to the top was for with the 741 and 555, looks as if its job is just to light an LED when it detects ripple voltage, either to give a reassuring indication that it still working, or to perhaps warn if the ripple on the output exceeds a certain value when a load is applied. Does that sound reasonable to everyone else?
Tue Nov 16 2010, 09:56AM
Yeah, that's the only function I can think of for it.
Indeed, this is a 1970s antique but no reason why it wouldn't still work. Using a PNP BJT as the switching device makes drive very easy, no high-side driver chips etc. needed.
Matt Edwards
Tue Nov 16 2010, 02:13PM
Thanks guys! It is the only variable low voltage PWM circuit that I could find online... I'm thinking about giving it a try since most of the components are so cheap.
