  • Guests: 141
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
850nm IR emitter for night illuminator ???
3l3ctrici7y
Sun Nov 14 2010, 05:54AM Print
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
Hi,
I am working to build an infrared illuminator for use with night time cameras.
The best thing I've found so far is this 3W star for 3.28 to 3.02 USD.
I doubt any better led power/USD could be easily found, though I would be happy to find one, but what I was thinking about is possibly other technologies that can produce near-infrared with low visible light. Even those LEDs are going to have a pronounced red glow, that is fine. The whole point is to illuminate the largest area for the camera/s with the least cost and not to be TOO visible. Electrical and thermal efficiency is irrelevant. Of utmost importance is brightness/cost.
For example, one does not use LED for large scale illumination; some sort of arc lamp is used, probably and HPS lamp or an MH if color rendering is more important than lm/W. In smaller scale, wide spread illumination, [compact] fluorescent is often used. My thought is that something similar might exist for near-infrared. Maybe some sort of "neon" style tube lighting with a certain gas mix/coating in it. One would probably drive it fairly hard. The "neon" approach would be very nice if it could have similar or better brightness/cost and brightness/area than an LED based solution.
Thank you,
3l3c
Sun Nov 14 2010, 06:30AM
IR LEDs are getting cheaper and "brighter" all the time,
but you can still get IR illuminators for large areas that use incandescent lamp with a visible-light-blocking filter. Could probably home-brew one --- look up Wratten 87 filter; think about a fan to keep the filter cool.
I don't know any gas-discharge type lamps that have good IR output.
3l3ctrici7y
Sun Nov 14 2010, 08:00PM
Incandescent with IR filter; I like.
Thank you.
