  • Guests: 39
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
VHF Filtering - School report Help
TechNerd
Wed Nov 10 2010, 09:51AM Print
TechNerd Registered Member #2289 Joined: Thu Aug 13 2009, 02:49PM
Hi All
I'm about to write a report on the subject "VHF Filtering"
As I understand it, the filters work like when handeling LF but the higher frequency changes the component values by a certain %.
The main questions are:
What is a 200Mhz filter used for?
What does the filters consist of?
How does digital filtering work at these frequencies
I need some not to complex explanitions on the subject or some weblinks..
hope to get some answers:-D
Wed Nov 10 2010, 10:34AM
Separating wanted VHF signals from unwanted ones. :P
Inductors and capacitors. At these high frequencies the inductors are air cored with only a few turns, and the capacitors are tiny ceramic ones.
Not very well. Typically it would be done with a very high speed A/D converter and a FPGA. ICs called "digital downconverters" also exist, these can take a small section of the VHF spectrum and translate it down to a lower sampling rate, where more complicated filtering can be done. This can also be done in a FPGA. All of this is expensive, complicated and uses lots of power.
