  • Guests: 47
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
how to pump MOAR power to a modern FBT?
haxor5354
Tue Nov 09 2010, 05:16AM Print
I just finished my "proper" ZVS driver today, all my previous ZVS drivers that blew up on me had the same issue and i just found that out a few days ago O.O
so the zener diodes HAS TO BE 12 VOLTS, before i knew that, i was being cheap and scavenge random glass diodes from scrap circuit boards.
no wonder the mosfets heats up so easily and explode! grr!grr!grr
now that I have made a proper ZVS driver, it can drive an extra large projection TV FBT flawlessly. After 10 minutes of play time, teh FBT was warmed up a bit and the mosfets were still at room temperature.
the arcs that I got from my FBT were about 3 or 4 inches and teh ignighting distance is about half an inch.
and yes I was using 24 volts from two 18Ah SLA for my ZVS driver.
I got 2 more 12Ah SLA batteries lying around... so would a 48 volt input for a ZVS driver such a good idea?
and what other things can I do to increase the performance of my FBT.
1289279812 2063 FT0 Dsc01014
1289279812 2063 FT0 Dsc01016
ScotchTapeLord
Tue Nov 09 2010, 12:17PM
If your flyback is heating up, that means you're reaching the limit of your flyback.
For more power you could switch to an H-bridge. Shouldn't be that hard to convert what you have to a half-bridge.
That will give you more control over the frequency and power.
ZakWolf
Tue Nov 09 2010, 05:04PM
You could try more or less primary windings or you could try a different and inductor with more or less inductance
ZakWolf
Tue Nov 09 2010, 05:18PM
how many amps are you powering it with ?
Tue Nov 09 2010, 08:54PM
If you want the driver to pull more current without raising the voltage, and are not too concerned with efficiency, there is a modification that apparently draws 35% more current. It is another 3+3 winding in parallel with the existing primary with 100 ohms in series with each winding, like this: Link2
But really, if you want more power, i would suggest winding your own AC transformer on a larger U core for maybe 6kvac. Depending on many factors, 2kw would be easy with the driver, though, your capacitor would die. A CDE .68uf 1600v cap would be nice for that, those never even heat up for me.
