  • Guests: 18
BlakFyre (36)
SENTRY (31)
05/01 Shaun (34)
05/01 Spedy (30)
05/02 Adam Munich (30)
Quick coilgun project: Single stage SCR V-switch coilgun pistol
TheMerovingian
Thu Jul 06 2006, 11:55AM Print
During these days i have built a pexiglass cased coilgun pistol.
Technical details:
Model: EMP090S1SDR
Exit speed:23 m/s (71mfeets/s)
Armature mass: 6g
Kinetic Energy: 1,6J joules
Starting voltage: 310V
End voltage:150V
Capacitance: 1900uF
Efficiency: 2,29%
Impactivity (P/surface): 4,9 Tons m^-1 s^-1
Charging circuit: 10W 300V Tl494-controlled boost converter (d2pak 600V fairchild igbt)
Capacitors: 1900uF worth of photoflashes
Display: lm3914
Pointer: 5mw laser pointer with screw-spring adjusting
switching: high side v-switch with GDT and magnetic sensing (coil on projectile entrance)
Snubbing: 30A ultrafast fairchild diode + 1,2ohms 10W wiredoun resistor
Coil: 98uH, 250mOhms
Power supply: 12V 1,2AH SLA
Charges in 9 seconds
pierces through cans.
blunt projectile with no gyroscopic stabilization.
1152186932 14 FT0 Foto269
1152186932 14 FT0 Foto270
Note: a feet is 30,5cm and mfeet is 32,8 cm
WaveRider
Thu Jul 06 2006, 01:06PM
Pretty E1ite gun you've got there! How did you come up with the model number? Are the LEDs for indicating the state of capacitor charge...
I like it...
Maz
Thu Jul 06 2006, 04:45PM
Maz Registered Member #111 Joined: Fri Feb 10 2006, 01:04AM
actually it is more like 73h 1337012Z!!!!111!!11oneone!
but some things just dont jive the way they should to me.
doing the electronics would have taken me at least a day of soldering (im a slow worker)
doing measurements, and cutting out the pattern for the gun must have taken a while as well.
so if you invested that much time into it, it pains me that you chose to use silicone caulk to hold it together and not Weld-on or glue of the sort...
either way, great work, keep it up!
TheMerovingian
Thu Jul 06 2006, 07:14PM
model number stands for:
EMx-yyyy-Szz-xx-Py-Tz
x= P (Electromagnetic Pistol) or R (Electromagnetic rifle)
yyyy = Start capacitor energy (joules)
zz = stages
xx = type (HB = halfbridge, SC = SCR, SDR = scr-vswitch, ID = igbt-diode, IDR = igbt-diode resistor, MD = mosfed diode, MDR = mosfet diode resistor)
y= number of pre stages (if 0, omit)
z= tyming type (A= analog, D= digital, if absent , omit)
The glue is hot glue, ideal for construction.
The leds indicate the voltage in divisions of 30V each
Note: on the chassis 1,2J 20m/s are written, to respect the firearm legal limit (in italy 1.35J).
rupidust
Fri Jul 07 2006, 01:02AM
rupidust Banned
Registered Member #110 Joined: Fri Feb 10 2006, 12:23AM
You may be cheating yourself out some feet per second. How are you converting m/s to f/s? Should be 1 m/s = 3.28 f/s. If you are then calculating joules based on f/s you could be having a slightly higher joule rating than you think.
TheMerovingian
Fri Jul 07 2006, 03:35PM
mmm actually you are right, but i used for my speedtrap a 2/10 of a "feet" taking it 6,56 cm of sensor spacing instead of 3,05. So the conversion unit from feets to meters is 1 feet = 0,328 meters
they arent actually feets but mfeets (merovingian feets cheesey )
a real international feet is 30,5 cm and a metre is 3,28 feets
so the meter x second are ok
1 mfeet = 1,09 real feets
so the speed in feets x second is 66
The sensor spacing is 6.56 centimeters
so
the projectile travelling at 23m/s
takes 2,85ms to trigger both sensors.
Since it is taken as 20% of the unit 0,2/0,00285 = 70mfeets/s
70mfeets/s = 22,95 m/s
6,56 / 0,2 , an mfeet is 32,8 cm
despite a feet is 30,5 cm
williamn
Fri Jul 07 2006, 10:31PM
williamn Registered Member #55 Joined: Thu Feb 09 2006, 04:56AM
Very cool Mero! I have one on the way too, you beat me too it :)
What type of sense coil did you use, this is something I have been playing around with, and results are pretty good.
William
Marko
Fri Jul 07 2006, 10:34PM
If someone wants t be really 1337 he should build a small railgun like such smile
I don't know if anyone actually got such a miniature (in 100's of joules range) railgun to work and give some significant thrust.. wink
FastMHz
Thu Jul 13 2006, 06:55PM
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
Nice work...and good efficiency too.
TheMerovingian
Fri Jul 14 2006, 11:44AM
The sensor is a bit atypic. It works on the v-switch principle, using two scr-s.
THe first is triggered by a gdt (and the trigger), the second is triggered from the induced voltage when the projectile exits the small coil, of course clamped by a 6V zener. The snubbing network is a 1.2ohm 10W wirewound resistor and a 30A Ultrafast fairchild diode to damp the field faster. A higher walue would be possible (approx 2.5 ohms) but in this case the simulation shows that the field damps too fast losing the chance to further accelerate the projectile during turn-off phase. The result is that the projectile is very fast, able to punch through a wall of a can full of water and seriously damaging the opposite wall, despite the friction of water. The projectile impact on a ferrous object damages it. A projectile bulged a bit and jammed upon fire in the launch tube, needing a screwdriver to get it out and lots of patience. It is dangerous for windows and peoples even with blunt projectiles.
