  • Guests: 92
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
Image Feature Extraction
rp181
Fri Jul 09 2010, 10:54PM Print
If I have an image:
And I want to pick out points, labeled here (with contrast adjusted of the image):
Which are basically the "bumps", what kind of neural network would i use? Or is this even suitable for neural networks?
I am thinking of using a Hopfield Network (similar to OCR?). However, how do i choose the amount of neurons? What is actually the input? The image pixels?
I plan on using Encog (for Java) to make a program to pick out these points, and i plan on using a Hopfield+levanberg (or backpropagation) network. However, i Can't find any good resources for image processing with Neural Networks.
Carbon_Rod
Sun Jul 11 2010, 01:39AM
You could also try FANN
However, you may find it rather disappointing given the performance of NN.
Cheers,
rp181
Tue Jul 20 2010, 11:04PM
What would be the best approach to detecting these points?
Carbon_Rod
Thu Jul 22 2010, 03:13AM
on-board Morphological and SLAM operations are currently computationally unfeasible for small UAVs.
However, there are exotic motion tracking cams built for noisy environments:
Perhaps a better question is... what precisely are you trying to accomplish?
i.e. Sobel edge detection is more efficient than most blob detection routines:
Cheers,
Arkin
Thu Jul 22 2010, 11:12AM
Arkin Registered Member #2140 Joined: Tue May 26 2009, 09:16PM
This is actually unrelated to the UAV. I am simply trying to count the amount of "bumps", or dislocations. The picture you are seeing is about 4 micrometers across, of galium nitride growth. This has to do with my internship at the NRL.
As for the UAV, I am actually recieving a couple Cent-eye sensors, and have the change to test them out.
That link is good one, about edge detection.
Carbon_Rod
Fri Jul 23 2010, 01:48AM
Interesting,
you could try a simple filter, find center of each contiguous area, and add a point tracker.
See OpenCV/samples/c/lkdemo.c for an example of automated feature position tracking.
Cheers,
]fast_points.cpp.txt[/file]
1279849710 65 FT92372 Output
Arkin
Fri Jul 23 2010, 11:19AM
I have actually got very close to what you got. However, the problem is detecting the points after that. If i were to do it myself, I would use flood fill. Instead, I have been trying to use the OpenCV blob detection, which should be perfect for this. However, the blob count seems to be capping at 257, even though there is an argument for the number of blobs.
I will see the demo you mentioned.
Carbon_Rod
Fri Jul 23 2010, 07:19PM
Connected Components labeling:
Should be trivial since the binary threshold call produces a b&w image.
opencv cvBlobsLib documentation:
LGPL cvBlob documentation:
Cheers,
