  • Guests: 36
01/08 Lyonel Baum (77)
01/08 Mattc1886 (17)
01/09 RickR (18)
FAST rotary position sensor
ramses
Sun Aug 01 2010, 09:06PM Print
ramses Registered Member #1208 Joined: Thu Jan 03 2008, 05:30PM
I need to read the angular position of a shaft rotating at around 3000 RPMs within +- 1 degree at any given instant with an ardiuno. I want to use an absolute analog sensor for simplicity. I have found a few possible sensors: here and here, as well as a continuous rotation potentiometer.
Unfortunately, the specified maximum sample rate of the first two are 2870 hz. What is the danger of exceeding this by, say, a factor of 20? Is there any easy way to have the arduino specify an output voltage at which some circuit would pull one of the digital I/O ports high? Something like a voltage controlled comparator? Only becasue digitalread is faster than analogread. Could this sensor be shared among a number of such comparators easily, possible between separate microcontrollers?
I also have to ask, how long do you think a continuous rotation potentiometer would last at 3000 RPM? The specified life is 1M rotations, so in theory it'd last 5:33:20 cheesey
Bjørn
Mon Aug 02 2010, 12:59AM
You need to explain what you try to do so we will be able to help you better. For example if it is a constant rpm device then you only need to read it with an optical sensor once per rotation and interpolate and you will get perfect positional data.
The sensors you linked to seems to have a fixed sample rate so they would be useless. A potentiometer would not last long, at that rpm it might fail within seconds.
A programmable comparator is easy, just use filtered PWM to give a voltage for a normal comparator.
ramses
Mon Aug 02 2010, 01:22AM
This is a camshaft position sensor. It will be geared down by a factor of 3, because this will be a 6 cycle engine. it will not be a constant RPM device, because of changing load, throttle position, etc. I was hoping to avoid interpolation becasue it requires processing power, which I don't really have to spare. In an ideal world, one arduino would control every aspect of the engine and transmission (including valve timing), but at 10K rpm, it has around 4800 clock cycles for every cycle, and must deliver at least 4 precisely timed pulses at specific times which are always changing based on a lookup table and sensor data. I'd probably be better off using a parallel port, but that takes away portability and requires external ADC's, and software based PWM.
One of the sensors has straight up analog input, as in it outputs 0-5V based on the angular position of the shaft, and is linear. Would something like that work with a comparator?
The potentiometer was suggested mostly as a joke. In the best case scenario, it would jitter like crazy, but there's only one way to find out.
I now realize how stupid my first post was, "voltage controlled comparator", as opposed to what?
Bjørn
Mon Aug 02 2010, 02:05AM
If processing power is a problem then replace the CPU with one 100 times more powerful, it makes little sense to waste time and money on an underpowered CPU when processing power is practically free.
If you are talking parallel port on a PC then it makes little sense since it is so slow that a microcontroller will be faster and the timing of a PC is very bad and unpredictable.
If you can afford it buy a suitable sensor, if not then buy the best you can afford and interpolate the rest.
Mon Aug 02 2010, 02:11AM
One thing you might want to look into is the ford EDIS system, which is available cheaply (I got mine for about $20 at the junkyard), which will take care of the timing for you. You just feed it a signal to tell it how much advance you want, and it has its own variable reluctance based CPS.
If you are sticking with a complete DIY system, you might want to look into VR based systems, generally you will use a wheel with 36 teeth (ie, 10 degrees per tooth), with one missing tooth so you know where TDC is. You can then interpolate across the 10 degree range, which you can use a simple linear fit for and get to much better than +/-1 degree. If you really wanted to go all out you could use a 360 tooth wheel, and have 1 pulse per rotation, but that seems a bit excessive and getting a reluctor that works at 20kHz would be a challenge.
ramses
Mon Aug 02 2010, 02:12PM
I am kind of partial to arduino, but can you suggest something more powerful? The Maple leaf? I mean, it would seem that a 16MHz microcontroller could control a 1 cylinder engine, but...
The EDIS system would be great, but I also need to control the pulse width of the output, how long the valve is open, etc. This is also going to be a 6 stroke engine, so using 4 stroke hardware could be an issue.
I'm still not clear on why the first sensor I linked to would have a maximum sample rate. The sin/cosine interpolation is likely hardware based, and should run very quickly.
Bjørn
Mon Aug 02 2010, 05:30PM
Maybe it has an internal microcontroller with a 1 kHz sample rate. It does not matter, the datasheet says it is slow.
There are countless fast 32 bit microcontrollers out there. I use these: Link2
hboy007
Tue Aug 03 2010, 11:17PM
The first thing that comes to my mind is the GP1A038, which is is an integrated optical quadrature encoder but it delivers up to 20kHz count rate. Inertia will smoothen the agular velocity over time, so this might be an option. However, the preferred solution in automotive applications is to use hall switches and multipolar permanent magnets as quadrature encoders because of the ruggedness and tolerance towards humidity, solvents, dust and oil. I am currently working on a servo motor driver that uses hall switches in a rotary encoder assembly to derive axis position, angular velocity and acelleration. The motor can run at well above 5000rpm.
