  • Guests: 24
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Little SSTC IR2153 driven
Tue Jun 01 2010, 07:24PM Print
I've just built a little demonstration SSTC. Here is its story:
- IR2153 driven
- half bridge of STGW30NC60W IGBTs
- 230 V full rectifyed input
- 25 cm long secondary with Fres around 194 kHz
- up to 20 cm streamers (enough for a demonstration coil), but full CW
The Fres can be lowered more with a little toroid. Lower resonant frequency of the secondary = better stability of the discharge when different objects are getting near the topload.
The schema is not original, I took it from here (thanx danyk):
http://danyk.wz.cz/sstc4.html
A few construction pics:
- cooling fans for the bridge, the switches, low voltage xfrm and the mains filter:
Th
Th
- instaling the bridge and the driver:
Th
Th
- manual winding of 1700 turns with 0.09 mm wire on a 11 cm diameter PVC pipe (bleah..)
Th
- the wire was to thin to solder so I used some alu tape:
Th
Th
Th
Th
Th
- varnishing and drying the secondary:
Th
- making the terminal caps from veroboard after removing the copper layer:
Th
- the primary is put in place:
Th
Th
- the whole thing:
Th
The results:
-without toroid:
http://www.youtube.com/user/teslina#p/a/u/1/Xmy24DULYOY
-with a little toroid hoter arcs:
http://www.youtube.com/user/teslina#p/a/u/0/EgIg10HxZqM
A new toy to play....weeee...!
Coronafix
Wed Jun 02 2010, 12:48AM
Cool Vasil, I like it a lot!!
