  • Guests: 22
hvguy (41)
thehappyelectron (14)
Justin (2024)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
First fullbridge sstc.
Sat Jun 12 2010, 10:57PM Print
In the past i have made numerous sstc's, fullbridges for drsstc experiments, and for transformer driving. But i have never made a fullbridge solid state Tesla coil. I have some parts sitting around, so i decided to make a sstc.
It will have an optional interrupter with burst mode and seperate frequency and duty cycle control for both the interrupter and burst mode. It is quite mini-sstc esque. I always hated using an entire 74hc14 even though i only needed 2 gates (which reminds me, for Steve Ward's mini sstc you only need one gate). I also hated working with 555's, because the duty cycle has to increase and decrease when the frequency is changed. So, the interrupter and burst mode consists of 4 pots, 4 capacitors, and i believe 6 resistors and a 74hc14 and 2 actives.
The rest of the driver is the 2 74HC14 gates i need for buffering and the one i need because my gate drivers are all non-inverting. After that it goes to the two 4 amp peak TO-220 gate drivers. That may not sound so great compared to the ucc37322 with it's 9 amp peak, but my gate drivers (UC3710T) can push 1 amp steady state. Not to mention heat sinking ability.
This will all be built into an ATX power supply box with a built in RFI filter, with a large external heatsink for the final amplification stage (G27N120BN IGBTs) mounted onto the outside of the box. I can pretty much ensure the insides with be very disorganized, but i will be able to minimize the GDT leads to maybe an inch 'round-trip' one the secondary, and a cm or two primary lead length...
Process is slow due to assorted reasons, but if i where able to stick with things, i could get it running by tomorrow.
Here are some cruddy pictures for now. Hopefully you can figure out what each one is wink
1276383474 1225 FT0 Fullbridge1 001
1276383474 1225 FT0 Fullbridge1 002
1276383474 1225 FT0 Fullbridge1 003
1276383474 1225 FT0 Fullbridge1 004
1276383474 1225 FT0 Fullbridge1 005
1276383474 1225 FT0 Fullbridge1 006
dmg
Thu Jun 24 2010, 01:04PM
hows this project going?
did you begin to put it together?
Matt Edwards
Sat Jun 26 2010, 08:04PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
I love the green wire! I could only find a red/copperish color. Do you purchase it online?
