  • Guests: 8
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
RepStrap
Fri Dec 11 2009, 12:50AM Print
Hi all.
Have just been reading Part 2 of the EPE RepRap article.
Most of the components could be built "kludge" style using a homemade build platform consisting of printer parts and steppers.
the most awkward assembly seems to be the extruder but this may not be as bad as it seems, considering that fire cement is cheap.
was looking into the possibility of using components from numerous HP all-in-one PSCs as i have three identical broken units.
anyone ever tried to build one of these?
so far the base plate and Z axis drive is somewhat planned, using a piece of non stick cutting board as the build platform.
-A
Dr. H.
Fri Dec 11 2009, 10:56AM
Good day sir
can you post a link to the article ?
Cheers smile
Fri Dec 11 2009, 06:39PM
regards, -A
"Bother" said Pooh, as he flashed his router with Nimda.dat ...
