  • Guests: 10
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
USB hub controller IC
Renesis
Mon Dec 07 2009, 12:24PM Print
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
Hi, i need an USB hub controller IC, but i cant seem to find any with through-hole soldering. Could anyone point me in the right direction?
Programming is not really my game, so using a microcontroller is not an option. High-speed would definately be preferable, and i need seven ports, but i dont mind cascading several IC's to achieve this.
Thanks!
plazmatron
Mon Dec 07 2009, 05:26PM
Most are in SMT packages, there is however one I found here! It is only a 4 port though.
TI do a 7 port version, but it is SMD only.
Les
Avalanche
Mon Dec 07 2009, 06:08PM
Some chip manufacturers will sell their smd chip on a daughterboard for prototyping, I think ftdi do this with their usb controllers.
Renesis
Mon Dec 07 2009, 06:17PM
plazmatron wrote ...
Les
That appears to be only a full-speed device. They are forty times slower than high-speed, but i cant find anything better. I have found some ideal devices in SOIC-packages, how difficult would it be for a novice to solder that?
Mon Dec 07 2009, 07:21PM
Not that hard, if you mean the regular 14, 16, 18, 20 pin SOICs.
You can solder almost anything short of a BGA by hand, if you have a steady hand. Tutorials are available on Youtube.
For BGAs, you need a steady hand plus a clothes iron smile
or Mike Harrison's SMT Toaster Link2
He's wrong though, you can get toaster ovens in the UK: I've seen them in John Lewis. They're probably called something else.
Renesis
Mon Dec 07 2009, 08:41PM
Steve McConner wrote ...
Seems like SMD's will be the way to go then. Thank you all.
mikeselectricstuff
Tue Dec 15 2009, 12:48AM
..but they are not nearly as common as they seem to be elsewhere... apart from SMD soldering, I can't really think what you'd use one for if you already have a pop-up toaster and a normal oven. "Mini Oven" brings up a few possibles at Argos.
This one from CPC seems promising - bought one recently but only toasted a couple of small PCBs in it so far - not sure how even the heating will be for bigger boards.
