  • Guests: 48
Mandelbrot project
Mon Dec 14 2009, 06:43PM Print
For my final programming task I need to draw some Mandlebrot fractals. This is quite easy to do when using the cpu for the calculations. Though I want to be able to do it faster. One way to do so is by using the GPU
The downside is that I have no idea how to start. Can anyone give me some tutorials about coding on the GPU. It needs to meet the following demands:
C++
OpenGL for rendering
Supporting ATI and Nvidia
If I get this to work I might try to write code for 3d Mandlebrot fractals.
Bjørn
Mon Dec 14 2009, 07:20PM
If you want to make the same program work efficiently on ATI and Nvidia (and on different models) you will have to sacrifice speed or you need to make many different programs. Mandlebrot fits quite well with GPU architectures, but you will have some problems getting over 32 bit resolution which will ruin a lot of the fun.
Forget about C++ for coding GPUs until everyone get some new cards in a few years, my Nvidia 8800 does not have an architecture that makes standard C++ very usable. It will not be a simple task to get efficient code that can zoom deeply running on many different cards.
See Link2 and Link2
Wed Dec 16 2009, 12:12PM
Ok if it's next to impossible I'll just try to use both cpu cores. Not that fast but it will work. 2d static images allready work now I just need to write the code for zooming to infinity.
