  • Guests: 29
M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
12/16 william L (29)
joining three tables in an SQL query
ragnar
Mon Sept 21 2009, 09:26AM Print
Hi all,
I'm trying to achieve what I think are two JOINs using the following tables:
TABLE messages
| client | customer | message |
| 1      | a        | foo     |
| 2      | b        | bar     |
| 3      | c        | baz     |
TABLE clients
| id | name |
| 1  | matt |
| 2  | john |
| 3  | mark |
TABLE customers
| id | name |
| a  | jane |
| b  | gina |
| c  | jess |
My desired results are:
RESULT
| client.name | customer.name | message |
| matt        | jane          | foo     |
| john        | gina          | bar     |
| mark        | jess          | baz     |
I've been messing around with queries for a while now, and I'm getting close with:
SELECT clients.name,customers.name,messages.message FROM messages
JOIN clients ON messages.client=clients.id
JOIN customers ON messages.customer=customers.id
However the result I am getting omits all message rows with a blank client, and the entire customer column remains empty. I know it's doing exactly what I've asked, but can anyone guide me to exactly what I need?
Myke
Mon Sept 21 2009, 10:13PM
I learned another way to do something similar to joins but I'm not sure if it will work completely. neutral
No harm in trying. I'm going to just guess at the ids of the tables.
Try:
SELECT client.name,customer.name,message FROM messages,clients,customers WHERE idclient = idclients AND idcustomer = idcustomers
Did you fill up all the tables including the look up table with information?
I'll test out the setup and see what happens.
EDIT: tested it out and it works fine
Here it is in mysql workbench
1253572231 540 FT1630 Client Test Db
I filled the tables out like you said you did and here is the code used to get the output you discribed:
SELECT name_client,name_customer,message FROM clients,customers,message WHERE clients_idclients=idclients AND customers_idcustomers=idcustomers
Oh, I see what you did. The messages table doesn't contain the names of the people that you are trying to look up. You have to have each table listed after the FROM.
ragnar
Wed Sept 23 2009, 02:17PM
Hi Myke,
I can't replicate your results: I just get empty tables. I do appreciate you setting up the tests to try to work out a solution, thanks.
To better word my problem, I really just want to dump the MESSAGES table, but replace the client/customer foreign keys with the respective client/customer names.
For now I am doing extra queries as PHP handles each row, but doing it with a single query would solve my performance problem wink
Myke
Wed Sept 23 2009, 09:49PM
Oh... You may want to look into left joins then. I don't know much about them besides they can have blanks in the right (I think).
