  • Guests: 16
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Wireless Lan
Ama
Tue Aug 18 2009, 03:08PM Print
Ama Registered Member #1852 Joined: Mon Dec 08 2008, 09:54PM
How can I connect a mobile phone(N91,wireless enabled) to PCI Wireless Lan installed in a PC to connect to internet? not using router, switch . . .
I can find the connection over my phone, but while trying to connect following error occurs:Unable to connect,Wlan Network not found.
Tue Aug 18 2009, 09:47PM
Are you trying to connect the computer to get internet through the phone or the phone to get to the internet from the phone through the computer which is connected to a modem of sorts?
The second one may be possible by creating an ad-hoc network on your computer, the first one would require a 3rd party (probably illegal) application for your phone.
Ama
Wed Aug 19 2009, 09:38AM
the second one, want to connect from phone to pc to access internet connection on pc(shared), so I can use my desktop internet over phone, I've created ad hoc, found the connection by phone, but unable to get connected, after searching a lot, for connecting phone to computer, found that it needs AP(access point) to be defined, I don't know to define AP over ad hoc!
Wed Aug 19 2009, 08:02PM
Maybe your phone just doesn't support ad-hoc mode. I wouldn't be surprised if this were the case.
Ama
Thu Aug 20 2009, 10:28AM
thanks Steve, problem solved.:-D
The problem was in phone's firm ware, I've tried to connect to ad-hoc directly from phones browser.
The phone's firmware did not support ad-hoc direct detection & connection, so after playing around settings in conn.manager and defining AP as ad-hoc on phone, managed to connect to wifi.
Thanks again.
