  • Guests: 16
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Power Supply Tester
cduma
Thu Aug 06 2009, 07:19PM Print
I am designing a power supply tester for a school project. What do you think are good max/min voltage limits for an ATX PSU? Prototype V1 is just a proof of concept and only measures the 12VDC line and displays an OK if it is between 11.6VDC and 12.5VDC. My lab partner wants to just hook up a variable power supply and see what the minimum running voltage is and what voltage lets the magic smoke out of the transistors.
Thu Aug 06 2009, 09:00PM
RTFATXSpecsheet! Link2 (page 13)
edit: Not to mention STFW Link2
cduma
Thu Aug 06 2009, 10:57PM
I dont think that the ATX spec sheet would be of any value since I am worried about the other hardware getting damaged. Thanks anyway! The first spec sheet was very interesting and has given me numerous more things to test for to insure the PSU is operating in a satisfactory way.
Fri Aug 07 2009, 04:45AM
Steve is trying to say that if the power supply outputs voltage in spec (11.4-12.6v, <120mv ripple) under its rated load it is 'working' and if anything else has a problem with that its not the power supply's fault.
thedatastream
Fri Aug 07 2009, 07:17AM
Some ideas of things to test
A low resistance load that you can switch in to check if the ATX PSU shuts down on an over current condition.
Remove all loads to see what happens - does it shut down or keep running?
If you toggle the PGOOD line, does everythign work OK?
If you remove the power, does the power fail line come up within the right amount of time?
Cross regulation: heavy load on 5V and no load on 12V - what happens? Vice versa.
Transient load testing?
Surge current on the 12V line (hard drive spinup)?
This level of testing demands some kind of automation
Fri Aug 07 2009, 09:41AM
cduma wrote ...
You asked for the max/min voltage limits. They're on page 13. So you're getting the exact answer to your question, straight from Intel. What more value do you want?
To explain further: That document describes a series of tests that a power supply must pass to qualify as an ATX power supply. So it also must be the recipe for building an ATX power supply tester. This level of testing would normally be done by engineers in the power supply maker's own labs, using standard test equipment like variacs, variable frequency power supplies and electronic loads Link2 ... especially the tests for "Startling noises" and "Emission of molten debris" aren't really suitable for a standalone tester smile
I'd consider a reasonable tester to be one that applied a decently hefty load to all of the outputs (again the document specifies how many amps per output, and so on) and checks that all the voltages are within the published tolerance bands.
cduma
Fri Aug 07 2009, 07:03PM
Steve, thedatastream thank you very much for your help! You have given me great information. I never thought to check if a heavy 12V load would effect 5V, 3.3V etc although I did think to apply a heavy load. I was going to make a multi-tap resistor out of some #22 wire since I have some pulled from a xformer worth about 1.1 ohms.
cduma
Fri Aug 07 2009, 07:06PM
I dont think that automation would be required. I have some old equipment with those dials that have a whole bunch of switches.
Fri Aug 07 2009, 07:36PM
cduma wrote ...
...I did think to apply a heavy load. I was going to make a multi-tap resistor out of some #22 wire since I have some pulled from a xformer worth about 1.1 ohms.
You could make all the loads you need out of AWG 22 copper wire, and will learn a lot along the way.
How are you planning to measure the currents, or to measure the load resistances at their operating temperature?
Some alternative materials for home-made low voltage loads at tens and hundreds of watts:
Nichrome wire from heating and cooking appliances (much less resistance change for a given temp. rise).
Steel wire or strapping (inexpensive at hardware store; thicker/shorter/less sensitive than copper for a given resistance and power).
12-volt incandescent lamps (resistance changes a LOT but reaches thermal equilibrium quickly. Then for small differences in DC voltage, they behave more like a constant-current source than a fixed resistor. But inrush current is several times greater than rated current -- better check ATX PS spec in that regard.)
cduma
Sat Aug 08 2009, 08:27PM
Toaster coils do make a lot more sense. Now that I think of it I have a toaster I bought for that purpose.
