  • Guests: 11
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Integer puzzle (with answer)
Bjørn
Tue Aug 11 2009, 06:48AM Print
This code will generate some of the possible combinations of x and y but it will repeat some combinations. How to generate the same combinations in the same order but skip the duplicates.
s = 256
Do
    s = s / 2
    For y = 0 To 255 - s Step s * 2
      For x = 0 To 255 - s Step s * 2
        Print x,y
      Next x
    Next y
Loop Until s = 1
Bjørn
Thu Aug 13 2009, 07:07AM
The solution turned out to be simple and the first value turned out to be a special case. For some reason most people found this problem to be confusing and difficult to visualise.
s = 256
Do
    s = s / 2
        If (x And s*2) Or (y And s*2) Or (s = 128) Then Print x,y
      Next x
    Next y
Loop Until s = 1
When doing in place wavelet transform of a picture, this is the order the transformed values have to be saved to a file or transmitted to make sure the image gradually increases in resolution as more values becomes available,
