  • Guests: 14
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Sending control codes to the console in C
scrooch
Sat Mar 28 2009, 12:30PM Print
scrooch Registered Member #908 Joined: Wed Jul 18 2007, 05:53AM
hi how do i send control codes such as "Enter", "Esc","ctrl+z" etc etc from C to the linux shell?
Sat Mar 28 2009, 07:22PM
You can usually escape them, though the exact syntax for escaping depends on how you're feeding stuff to the shell.
If you were using sprintf() to stuff command lines through a pipe, or something, then you can escape things in C string constants with a backslash. There are letters for common ones, for instance \n is a newline, or you can type the ASCII code you want after the backslash (in octal mind you!)
Also C lets you append hex constants sometimes. For instance
sprintf(buffer, "rm -f -r *\n") // \n adds a newline
char MyCommand[20];
MyCommand={"Whee", 0x0d, 0x0a}; // Whee, CR, LF
and so on.
I guess if you want to escape an escape, the ASCII code for ESC is 0x13.
Finally bear in mind not all systems are ASCII any more, some use Unicode.
