Voltage Multiplier
lhl_henrylui
Thu Jan 01 2009, 07:06AM
Registered Member #1498
Voltage multiplier's voltage is bigger than the voltage of the capacitors of the multiplier.Is it OK?
Myke
Registered Member #540
It depends on the configuration of the multiplier. If you are making a multiplier like this then the max voltage any cap will see is 2x the input voltage. The first cap will only see 1x the input voltage though.
