Registered Member #15
I'm presently faced with a difficult problem, in which some of you guy's expertise may be able to help out with.
Basically, the problem is determining how much energy is dissipated in an arc event. Very little information is available regarding this, and what information is available, usually conflicts with other information on the same topic.
For an example problem, say you have 10uF of capacitance which is charged at 50kV. You initiate an arc discharge (assume 100% discharge of capacitor) through a 100 ohm resistor. Now how much energy is dissipated in the arc? Assume the arc path is very short.
The energy of the capacitor itself is 12.5kJ. However, if you go on available documentation, the actual arc is very small in voltage (about 100V) which maintains a constant voltage over much of the discharge, so by energy calculations, the actual energy discharge is about 50mJ and the majority of the energy dissipated in the resistors.
However, this doesn't make much sense to me, as I've seen what 12.5kJ can do, even when discharged through a 100 ohm resistor.
Registered Member #1062
It would be hard to measure accurately with all the variables. Maybe you could use dimensional properties to measure the energy, like the arc volume/density, light emitted and sound.
Registered Member #30
Use a high-speed DSO to sample the arc volt drop and arc current, multiply them together sample-by-sample, and integrate. Some good DSOs will do this and display a trace of energy, if not, you can do it in Excel.
Arc drops start to increase again at really high currents. For instance, when the current density gets above what the electrodes can emit, an extra voltage drop appears, the energy of which goes into blowing the electrodes into tiny pieces. When energies get really high, the plasma tries to expand at supersonic speeds and is prevented from expanding freely by its own shockwave, which increases the drop still more, and so on.
Registered Member #834
A capacitive discharge arc is oscillatory. The current goes back and forth over the nonlinear resistor untill all the energy is dissipated. There is inductance in the discharge path too, so it's incorrect to assume that the capacitor voltage is applied to a small (nonlinear) resistor.
Antonio wrote ...
Not with a series limiting resistor. The resistor critically damps almost all oscillations. In fact, both my voltage and current discharges are nice exponential decaying waveforms - no oscillations period. Of course, without the series resistor, you definetely get some serious oscillation action.
I did some testing two days ago and got good results. Basically measured the voltage and current, and then used the Math function on the DSO to multiple the current / voltage. From there i can easily determine the energy from area under the curve. Seems to match the equations i have.
Registered Member #1890
Measure the temperature rise of the resistors.
Calibrate by shorting the arc and doing a small discharge through just the resistors to find the temperature rise from that energy. Then after you fire an arc, you can calculate probably a pretty good estimate of the energy dissapated in the resistors.
Registered Member #152
davidb wrote ...
I think this would not work... Quote from the OP:
wrote ... the actual energy discharge is about 50mJ and the majority of the energy dissipated in the resistors.
So the energy difference with shorted and open gap is about 0.00004%
Registered Member #347
Dr. GigaVolt wrote ...
Since the energy dissipated is defined as the integral of voltage*current in the arc, isn't this measurement the best way to go? Why try to calculate that which you can measure precisely?
Registered Member #222
Have you also taken into consideration the energy dissipated inside the capacitor?
Assuming the equivalent average resistance of the arc weighted by current squared is constant, the amount of energy disspated in the arc is related to resistance of the resistor. The arc and resistor form a voltage divider; if the resistance of the resistor drops, then the amount of energy dissipated in the arc must go up assuming the arc resistance is constant.
