Voltage Multiplier
lhl_henrylui, Thu Jan 01 2009, 07:06AM
Voltage multiplier's voltage is bigger than the voltage of the capacitors of the multiplier.Is it OK?
Voltage Multiplier
Myke, Thu Jan 01 2009, 07:10AM
It depends on the configuration of the multiplier. If you are making a multiplier like
this then the max voltage any cap will see is 2x the input voltage. The first cap will only see 1x the input voltage though.
