  • Guests: 35
dan (38)
rchydro (65)
CapRack (31)
11/07 Dave Marshall (41)
11/07 Worms (47)
11/08 Bert (78)
have a quick question about recursion
scrooch
Sun Sept 28 2008, 01:10PM Print
scrooch Registered Member #908 Joined: Wed Jul 18 2007, 05:53AM
the following code denotes a void method
but when the code says "return"
what does it return?
how does the return statement work when no return value is specified in front of it?
how can it return anything when its a void method to start with?
public class Merge {
    public static void sort(Comparable[] a) {
        sort(a, 0, a.length);
    // Sort a[lo, hi).
    public static void sort(Comparable[] a, int lo, int hi) {
        int N = hi - lo;        // number of elements to sort
        // 0- or 1-element file, so we're done
        if (N <= 1) return;
        // recursively sort left and right halves
        int mid = lo + N/2;
        sort(a, lo, mid);
        sort(a, mid, hi);
        // merge two sorted subarrays
        Comparable[] aux = new Comparable[N];
        int i = lo, j = mid;
        for (int k = 0; k < N; k++) {
            if      (i == mid)  aux[k] = a[j++];
            else if (j == hi)   aux[k] = a[i++];
            else if (a[j].compareTo(a[i]) < 0) aux[k] = a[j++];
            else                               aux[k] = a[i++];
        // copy back
            a[lo + k] = aux[k];
thanks for your help
Bjørn
Sun Sept 28 2008, 02:22PM
It does not return anything. The work seems to be done in an array that is in "shared" memory. The return just returns control to the caller.
Mon Sept 29 2008, 07:43AM
Indeed, the array a is sorted in place. Remember that in C/C++, when you pass an array as an argument to a function, you're just passing a pointer to its first element, so a is the same array throughout, and when sort finally returns, it's been sorted.
For a more in-depth explanation of recursion, see recursion smile
scrooch
Mon Sept 29 2008, 07:45AM
thanks for that. i was confused what a return statement was doing in a void method.
Mon Sept 29 2008, 07:54AM
He needs to use it to terminate the recursion. Every recursive function needs a way to make it finally stop. As in, Recursion: see recursion, until you get bored, then go for a coffee break.
Remember that return is a statement for program flow control, like break, continue or even goto ill If you don't give return an argument, it doesn't try to return anything, so it's OK to use it in a void function. But it still has the desired effect on the program flow.
