  • Guests: 59
mileswaldron (59)
06/04 muze801 (33)
06/05 HVgeek (33)
06/05 jmorlockny (50)
DSL/Ethernet Problems
Backyard Skunkworks
Tue Jul 01 2008, 03:08AM Print
I've got 1.5mbps DSL from earthlink (verizon is the actual provider) with a ZyXEL modem/router connected through 100T ethernet. It's had been working fine until I tried to configure my NIC card and router for a static local IP (using this guide: Link2 ), something must have gone wrong at some point! I had gotten the static IP set up and then disabled DHCP on my modem/router thing, at which point I could no longer connect to the internet, or even get back to the modem config page!
My NIC card is fine, it even sees that there is something connected to to it when the modem is on. The modem also reports that ethernet is working. I just can't get DSL to work at all, netstat turns up everything as blank. I'm back to my monthly 20 free hours 56k until tech support can do anything. frown
Something is definatly screwed up with either the modem or the NIC settings.
BTW: the reset button on the modem/router doesn't seem to do anything.
EDIT: With dialup on, oddly, I can access the modem's config page at 192.168.1.1.
Tue Jul 01 2008, 03:27AM
Hold the reset button on the router down for 30 seconds. Then reset your NIC to use DHCP. You'll regain connectivity.
Double check the local IP address, DNS, and gateway addresses you gave your NIC. For whatever reason, one of your settings is outside the router's current configuration.
It sounds like it could potentially be an IP conflict between the router and your computer, or your computer and the modem.
You shouldn't need to disable DHCP on your router to configure a static IP address for your computer. Simply setting your NIC to use an IP address outside the router's DHCP address block will usually get it working just fine.
As an example, if your router used 192.168.1.1 as its IP, chances are good the DHCP block is 192.168.1.100 to 192.168.1.200 or similar. Setting your NIC to use a static address of 192.168.1.25 should permit it to connect to the router just fine, and its highly unlikely that your modem is using .1.25, ensuring there won't be an IP conflict.
Dave
Backyard Skunkworks
Tue Jul 01 2008, 03:57AM
Thanks, Dave! smile
I got DHCP re-enabled a few minutes ago and DSL is working again.
The whole reason for this is because Vuze seems to be the only torrent program that allows you to pick one single file out a huge torrent. And Vuze is a real ***** about port settings. Any other torrent programs out there that let me pick one file out of a huge torrent for downloading?
If not, I'll try to get my DSL as static local IP tommorow.
Dago
Tue Jul 01 2008, 10:17AM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
Backyard Skunkworks wrote ...
Thanks, Dave! smile
µTorrent can do that and 1000 other things + its very light.
Tue Jul 01 2008, 03:29PM
but it will still not get great speeds unless you open up a port for it.
You should be able to get away with assigning yourself a static IP at an addres that your router is never going to assign anyway. If you have 5 computers that will get addresses in the 192.168.1.2-10 range, you can statically set your computer at like 192.168.1.240 you should be fine (make sure to use the same 255.255.255.0 subnet mask and 192.168.1.1 default gateway, you can use 192.168.1.1 for your dns server, or 208.67.222.222 if you like opendns.com, or whatever was shown in ipconfig -a). Unless you have a really big lan party some day...
BTW, the guide you were using makes no mention of what hapens when you assign your computer an address that you router has already given to a different computer--neither of the computers work properly.
