  • Guests: 28
Adam Munich (30)
Alfredo Texacca (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Calculating amps
buzzer
Sun Jun 22 2008, 01:50PM Print
buzzer Registered Member #680 Joined: Fri May 04 2007, 03:20PM
I am not sure how to figure amps in a circuit in regards to the resistance in the capacitor bank. I have 6 capacitors in parallel. Each is rated 450 volts 3900mF. I don't know the ESR. If I knew the ESR of one capacitor, how do you calculate the total resistance of the capacitor bank?
rp181
Sun Jun 22 2008, 02:57PM
If all the caps are in parrallel, the ESR is equal to that of one capacitor. In series, it adds, ESRxnumber of caps.
buzzer
Sun Jun 22 2008, 03:38PM
Help me.
I thought the resistance in parallel is divided by the number of resistors. Is ESR somehow different?
And once I get the resistance of the capacitor bank calculated, do I just add that figure to the resistance of rest of the circuit? The circuit consists of a coil, SCR, connecting bars and the capacitors.
ea6b607
Sun Jun 22 2008, 04:14PM
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
ya I'm pretty sure resistance will just be a work equation or as you said if they are all identical caps then divide the esr by the number of caps. Add that to the resistance of the rest of the circuit and you have the total resistance.
rp181
Sun Jun 22 2008, 05:15PM
hmm, might be like that, it does with regular resistors.
