  • Guests: 18
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Debian Won't Boot
Zonalklism
Sat Feb 09 2008, 05:51PM Print
Zonalklism Registered Member #213 Joined: Sun Feb 19 2006, 05:48PM
After an appaerently sucessful Debian install, I booted, (well, *tried* to boot Debian) however, it just wouldn't work. It lets me select it from the GRUB menu, but after it goes through the pre-start diagnostics, it just gives me a blank screen. The backlight is on, but that's it. I've tried re-installing it about 5 or 6 times now, with different options, but nothing works. What's the problem?
Btw, I'm installing it on a Compaq Presario V6305NR.
Carbon_Rod
Sun Feb 10 2008, 06:32PM
Are you installing Debian, or a variant like Ubuntu?
Some kernels do need to be setup for some hardware, but IIRC the HP/Compaq do not. Try Ctrl+Alt+F1 to switch to a command terminal. If it does not exsist, chances are the kernel did not load properly.
It is more likely you have a non-standard wide screen LCD, and are having trouble since the OS does not keep track of every possible monitor quirk on the market.
In Ubuntu, one may override the default max resolution by passing a kernel parameter at boot time:
xres=1024x768
And adjust the resolution on the OS desktop later.
Cheers,
Zonalklism
Mon Feb 11 2008, 07:48PM
I'm installing Debian. (not a variant) However I do have Ubuntu on order, and it should be getting here soon. My laptop does indeed have a widescreen display, and that sounds like the most likely answer to the problem.
"In Ubuntu, one may override the default max resolution by passing a kernel parameter at boot time:
xres=1024x768"
Will this also work in Debian?
And my final question...I love working on computers and figuring out the problem myself, but is trying to get Debian to work worth the trouble, or should I just wait for my copy of Ubuntu to get here?
Carbon_Rod
Wed Feb 13 2008, 12:12AM
IIRC Debian is vga= some number,
Ubuntu is nice for a desktop (after some tweaking to get the wireless working.) Debian has better security with server setups.
Zonalklism
Fri Feb 15 2008, 12:43PM
Thanks for the help, y'all. I tried some more with Debian, however, my copy of Ubuntu arrived yesterday, and it installed without any problems. So I believe I'll be sticking with that.
"Ubuntu is nice for a desktop (after some tweaking to get the wireless working.)" - Carbon Rod
Now I'm working on getting the wireless to work...
