  • Guests: 22
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Optimal Forth stack operations
Bjørn
Sun Dec 16 2007, 07:44PM Print
A stack that is 6 levels deep can be reordered in 6! = 720 different ways. I tested all 3.5 billion Forth programs that are 10 words or shorter and found 436 different reorderings, the remaining 284 would take more than 10 words to reach.
These are the possible words:
"nop", "drop", "swap", "rot", "-rot", ">r", "r>", "dup", "over", "nip", "tuck"
Only "nop", "swap", "rot", "-rot", ">r", "r>" are actually used since the other words are less efficient in reordering.
The idea behind this is to find the optimal code for every possible way to manipulate the stack for use in a Forth optimizer/compiler to generate optimal code for stack manipulation to a limited depth.
The attached text file lists all reorderings that are reachable by 10 words or shorter and the shortest possible code to reach them.
]1197834289_27_FT0_optimal_programs.txt[/file]
