  • Guests: 19
06/02 GreySoul (45)
06/02 GluD (35)
06/02 northern_lightning (41)
DIY USB PIC programmers?
Bjørn
Wed Jul 25 2007, 04:09AM
Doing USB in software is not impossible and the 16F84 might just be fast enough. The amount of program memory and RAM is on the low side but it is probably possible to fit it. You only need to do 1.5Mbit/s to do USB.
J. Aaron Holmes
Mon Aug 13 2007, 04:37AM
Uzzors wrote ...
I've been looking for a DIY USB PIC programmer, but I haven't found anything but commercial products. Is there a DIY programmer out there?
Only barely DIY: Get a PICKit 1 and solder a ZIF socket onto the protoboard that's attached. That's what I did, and it's been a fine programmer for years. Unless the programmer itself is something you want to build, the idea of a DIY programmer is kind of a strange thing to me when the non-DIY sort are so damned cheap nowadays!
On the USB thing in general: Going to PIC18 just to get FLASH and USB in one package and then futzing around with all the various USB firmware floating around out there is good challenge, even for those who have been hacking around with PICs for some time. One option you might consider, if you're ok with "pseudo-DIY" USB, is the FT245R by FTDI. It's a USB-to-parallel FIFO IC with free drivers for several OSes. Looks like it would be a total breeze to wire to a PIC, and then it's basically all over. They also make the UM245R, which is a DIP evaluation module complete with USB port. I've been about to order one for a little while now smile Just waiting for that USB-needing project to come along:
http://www.ftdichip.com/Products/EvaluationKits/UM245R.htm
The FT245R's are a couple of bucks, but are only available in surface-mount packages. The UM245R evluation module is ~$20 (USD), however it's hopelessly convenient as a way to prototype USB devices on a breadboard. Of course $20 is more than you'll pay for a used PICKit 1 or 2 on eBay wink
Cheers,
Aaron, N7OE
Electroholic
Mon Aug 13 2007, 07:21AM
I guess I'm lucky/a different generation, I have access to the ICD2 puck from microchip. And I only wright in C, never touched a single line of assembly.
right now, I'm working on a CAN network for the university's solarcar using teh 18f458 with MCP2551.
Mon Aug 13 2007, 09:20AM
I like the ICD2 too. I've also used the FT232 from FTDI to convert one of my old RS232-based instruments to USB.
J. Aaron Holmes
Mon Aug 13 2007, 04:34PM
Electroholic wrote ...
Just depends on what you're doing. Assembly on the PIC12/16 devices is about the easiest assembly coding you'll ever do, especially because most C programs written for the PIC12/16 still mainly seem to be long sequences of register assignments that translate line-for-line into assembly anyway wink If you need precise timing, however, you'll eventually warm up to the idea of using assmbly, simply because it's easy to make timing mistakes in C, or otherwise subject yourself to implementation details of the compiler. For example, compilers must assume that the order in which you make register assignments is important, and yet because registers exist in different "banks" in the PIC, the order in which you make assignments may greatly influence the amount of code emitted. There are other pitfalls too. I've never used the PIC18/24 devices, however I know they have about 2x the instruction set of the PIC12/16, so I'm sure the difference in "comfort" between C and assembly is definitely greater on the more complex devices.
Cheers,
Aaron, N7OE
ragnar
Tue Aug 14 2007, 12:55AM
Does a USB > Serial converter module count as a PIC programmer? =P
J. Aaron Holmes
Tue Aug 14 2007, 02:29AM
BlackPlasma wrote ...
No. But I was referring to the USB > parallel converter, not USB > serial wink The FT245R in "bit bang" mode is about all you need to do ICSP via USB. The USB-to-parallel FIFO ICs are awesome for a lot of reasons.
Cheers,
Aaron, N7OE
Sun Dec 09 2007, 04:47PM
I'm about to start building the "Brenner8" which Mikkel found. Not having taken German in school, I have to use babelfish so it's pretty unclear what to do. Here's the babelfish translation, everything you need to know should be on that page. Link2
Do I need an external programmer to program the 18F2550 with the bootloader first, then build the circuit, and finally program the 18F2550 with the firmware? Or is an external programmer even needed?
Wolfram
Sun Dec 09 2007, 10:15PM
Yes, you need to program the 2550 with an external programmer. A breadboard JDM and WinPic800 worked fine for me.
Anders M.
Mon Dec 10 2007, 08:17PM
It's quite the professional programmer, with it's own driver and all, I felt like I had bought a commercial product! Everything seems to be working nicely, but the Vpp voltage is way too low. When I use the graph function the voltage hardly rises no matter what duty cycle is used. It never leaves 5V... I'm going to check things over carefully so while I'm doing so; I used a physically small inductor for the boost inductor with 20 ohms of DC resistance, is it the problem? It's the size of a 1/2 watt resistor. What kind of inductor did you use Anders? I used a BAT43 diode which is what is specified in the schematic, and a BC337 transistor.
