  • Guests: 16
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
PIC programmer problems
Dr. Shark
Thu Apr 19 2007, 03:40PM Print
After about 5 years of abstinence I am trying to get back into µ-Controllers. I don't have that DOS laptop with the Dave Tait programmer software anymore, so I tried upgrading to the JDM programmer Link2 running IC-Prog software Link2
For some funny reason though, stuff does not work. If I start IC-PRog (even with no programmer connected to the RS232 port) I get an error saying "privileged instruction" and if I try burning a PIC the program crashes. I wonder if there is any other good software I could try running? I am on my girlfriends Windows 2000 PC, if that matters.
Oh, and is there a PIC programmer for Macintosh I could try?
ConKbot of Doom
Thu Apr 19 2007, 04:09PM
Do you have the windows 2k/xp driver installed to allow direct access to the serial port for IC prog?
Dr. Shark
Thu Apr 19 2007, 04:56PM
Thanks for your reply. I did install "DriverLINX Port I/O Driver" which I suppose is what you are referring to.
I also tried WinPicProg and PonyProg without success now, so I guess I will have to debug my programmer some. Maybe changing component values at will was not such a good idea after all smile
Wolfram
Thu Apr 19 2007, 09:51PM
There is a 2k/XP driver for IC-Prog on it's webpage. I'd however recommend winpic800 instead, far superior to anything else I've used.
Fri Apr 20 2007, 12:12PM
I had the same problem just recently. Luckily I wrote down how I solved it.
Download ICprog and NT/2000/XP Driver
1. Extract Icprog to any folder
2. Extract Driver to same folder
3. Run ICprog, ignore error messages
4. Settings -> Options -> Misc -> Disable NT/2000/XP driver
5. Enable Disable NT/2000/XP driver, allow ICprog to restart
6. Allow driver to be installed
That should allow parrallel/serial port access. Select "Direct I/O" in the hardware options menu. I'm using the Bob Blick Dave Tait Programmer.
Dr. Shark
Fri Apr 20 2007, 03:03PM
OK, I hope you guys set me on the right path. The problem with the other programmers I tried was that they had no option for "JDM Programmer" so I could not set them up correctly. I kind of sucks when you don't know whether the problem is the computer (some modern computers don't have enough voltage on the RS232, correct?), the programmer or the software...
Bjørn
Fri Apr 20 2007, 03:14PM
Some computers have far too low voltage on the RS-232 port for PIC programming. To save power some go down to 5V or even 3.3V in some cases.
McFluffin
Fri Apr 20 2007, 06:27PM
McFluffin Registered Member #119 Joined: Fri Feb 10 2006, 06:26AM
I had some problems with ICSP using a JDM. I had to turn it down to a really low clock, otherwise I didn't get enough power to program it. It was suggested to me to externally power it instead of using the computer's COM port's power, but I haven't tried that yet. I recently picked up a ICD-2 which I'm hoping will solve a lot of my problems after talking to some Microchip people at the Embedded Systems Conference in San Jose.
Dr. Shark
Fri Apr 20 2007, 06:56PM
You guys fucking rule! After installing the WinNT driver (which I had previously failed to notice) and following the instructions, everything works fine now.
Thanks!
BTW, the JDM is highly recommended for minimal parts count and RS232 is a lot more comon that parallel port anyway.
Wolfram
Fri Apr 20 2007, 08:40PM
Tried WinPic800 (Link2) yet? It beats Icprog when it comes to device support, user interface and programmer options. It will even program dsPICs with a JDM. It can also autoidentify the PIC connected to the programmer and show a short summary of the datasheet of the chosen PIC. It is also regularly updated. IMO Icprog simply sucks compared to WP800.
