  • Guests: 27
Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
DRSSTC 2 SIMULATION PROBLEMS
gentoo_daemon
Sat Feb 10 2007, 06:39PM Print
gentoo_daemon Registered Member #512 Joined: Sat Feb 10 2007, 05:42PM
Hello.
My name is Rick. I'm a brand new member, and a beginner solid state coiler. I'm trying to reproduce Steve Ward's DRSSTC 2. Before I start building, I wanted to understand/simulate his interrupt and driver circuitry. I am using workbench multisim 9.0 to simulate his basic interrupter found on his design guide. I'm inputting a 42 kHz sine wave to simulate the feedback from the coil, and observing the output of the JK flip flop with the multisim O-scope.
The problem is that the output ~Q goes high for a few periods, and then stays low (much like a 1-shot). Initially I believed the problem maybe the astable 555 (the one with 2 POTS) since it wasn't changing states, I replaced with a different configurations, but then ~Q stays on the high state.
From my understanding Steve's design is supposed to clip the feedback sine wave, add some hysteresis, and pass it through the JKFF, which is configured to be a T FF since both the inputs are tied high. With the input at the clk, wouldn't this just cut the feedback frequency in half? The astable 555 sets the duty cycle while the comparator and 1-shot make sure it is in sync with the feedback. Feel free to correct my understanding.
I've attached the multisim circuit as well as a JPEG screen shot.
Here are links just in case
Any ideas?
-Rick.
Sat Feb 10 2007, 08:18PM
Its not a T FF, its acting as a SET. When the 555 astable is high, the ~Q output is forced high by the /clear input. When the 555 astable falls low, this then allows the FF to act as a FF, with J and K tied high (Note that K input is INVERTED!) the next clock input should force ~Q low. The only function of this flip flop is to stop gate drive at a current zero crossing (synchronizing, if you will). Your simulation has K tied low (meaning it will be a toggle FF, you DONT want this).
There are of course other ways of wiring the FF to do the same thing.
You may want to have your simulation toggle the SET once at the start of your simulation, i know this is required in pspice before you try doing anything with the flip flops (supposing you want them to work properly).
Let me know if the purpose of the flip flop is still unclear to you. Also note that the clock signal (derived from the feedback) is also fed into the gate drivers. The FF only controls the ENABLE of the drivers. The result should be a train of clock pulses that is then shut down at a rising clock edge after the 555 timer falls low.
gentoo_daemon
Sun Feb 11 2007, 07:45PM
thanks steve.
I'll change the pins on the JKFF.
There are 3 pots on the circuit Link2 . Around what values did you set those to?
Also I wanted to use just your basic interrupter found in your design guide with the bigger EUPEC IGBTs. In other words, I don't plan on using the boost converter found under the DRRSTC2 section. The mosfet drivers will be connected to the 1:2:2 GDT and then to the half bridge. Do you think this will work okay?
Wed Feb 14 2007, 05:56AM
Your setup sounds OK. Really, though, its hard to drive big IGBTs with a GDT. You will probably want to parallel more gate drivers on the output.
As to the pot settings, they are supposed to work at very wide ranges. The only one that should be "set" is the pot that sets the Vref on the LM311 comparator (this sets the current limit level). If you know the ratio of your CT, the burden resistance, and the current you want to limit too, you can figure out roughly where this pot should be set. Say you have 1000A primary current max, and a 1000:1 CT ratio, that means 1A at the CT output. Say its got 10 ohms loading it, that gives 10V across the resistor. Thus, you would want to set Vref to 10V. This doesnt account for the diode drop of the full wave rectifier on the CT, so you would end up limiting too high. Its best to use trial and error.
gentoo_daemon
Thu Feb 22 2007, 05:58AM
Steve
When you say place the drivers in parallel, you mean place two GDTs in parallel to drive one IGBT, and not two ti ucc37322/1 mosfet drivers in parallel to drive one GDT correct?
So I would end up having to use two 37322s, each with their own GDTs, and then those GDT would be in parallel?
Same for the 37321s?
What do you think is more likely to destroy the IGBTs, over current from a badly built OCD circuit, or having too high of a duty cycle from the 555? the 4hv wiki mentions that igbt failure usually occurs instantaneously, so I want to do much as possible to avoid it.
Thanks again.
cheesey
Thu Feb 22 2007, 09:27PM
No, the exact opposite. You only need 1 GDT winding per IGBT gate, but you will want higher current drive on the primary of the GDT. Paralleling windings doesnt help unless your primary has a lower impedance source. But in general, R(gdt) << R(driver) so you dont need to parallel windings or anything but you do want to parallel the gate driver chips for lower resistance on their output.
Thu Feb 22 2007, 09:29PM
Well... both aspects are highly controllable. You are more likely to lose an IGBT from poor bridge design, which can promote voltage spikes across the IGBTs. And of course the failure is instantaneous, its either working fine or its blown, so im not sure what the HV wiki meant by that.
Thu Feb 22 2007, 11:10PM
Well, if there's stuff in the HV Wiki that you disagree with, please edit it! smile And don't believe anything you see in a simulation wink
gentoo_daemon
Wed Feb 28 2007, 05:03PM
thanks for your patience Steve.
I'm having trouble picturing the feedback ferrite core transformers (1:33).
http://stevehv.4hv.org/DRSSTC1/controller1.JPG
Controller1
In this case, you are using primary feedback (?). is it okay to use such a small gauge of wire to wrap that 1 turn considering that 2 of these transformer will go in series with the primary LC? Does this not raise the impedance?
Bennem
Wed Feb 28 2007, 06:36PM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Hi Gentoo,
I beleive that picture of Steves is when he used secondary feedback,
so that picture is of his secondary cable going through the ferrite core.
hence the lower gauge of wire.
