  • Guests: 38
buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
DOS File Command
Nucleophobe
Fri Jan 19 2007, 11:28PM Print
Nucleophobe Registered Member #108 Joined: Thu Feb 09 2006, 11:44PM
Does anyone know what DOS copy command you would use to copy one file into multiple folders??
For instance, I have in my directory:
foo.txt
DirectoryA\
DirectoryB\
DirectoryC\
Dire ctoryD\
DirectoryE\
I thought something like "copy foo.txt *\" would work, but it gives syntax errors (doesn't like a wildcard for the folder name). Does anyone know how to do this? I could do it with a VB script instead maybe, but I don't have very much experience there.
Thanks,
Ken A.
Alex
Sat Jan 20 2007, 12:37AM
Alex Geometrically Frustrated
Registered Member #6 Joined: Thu Feb 02 2006, 04:18AM
From directory foo with file bar..
FOR /F %i IN ('dir /B /AD .') DO copy foo %i\.
Nucleophobe
Sun Jan 21 2007, 08:12PM
Thanks Alex. I had to play with it a bit but it worked like a charm (the folders has spaces in their names)
Nucleophobe
Tue Feb 06 2007, 03:04AM
Ok, I have another couple questions.
I have this code, which reads the first and second token from foo.txt (which is someones first and last name), then creates a folder "lastname, firstname" and copies foo.txt to the new folder with a new filename as well as a second file that is the same as "foo.txt" except it looks something like "foo-otherstuff.prt".
My code works, but there is three problems.
A) what is the best way to read ONLY the second and third token from a file, ignoring all lines after the first?
B) I kept getting more folders than expected, which were named ",foo.txt" (the reason for the skip label)
C) Xcopy prompts me to answer whether the destination is a file or directory. the "/i" switch suppressed this prompt under the assumption that the destination is a directory, but is there a way to suppress the prompt under the assumption that the destination is a file? (there are 100+ files!)
FOR %%i IN (*.txt) DO call :read_name %%i
:read_name
REM store filename in variable
set _file=%1
REM store file contents in string
Set /P _filestuff=<%_file%
REM look through first 20 characters, storing tokens 2 and 3
FOR /F "tokens=2,3" %%i IN ("%_filestuff:~1,20%") DO call :copy_files %%i, %%j
:copy_files
set _firstname=%1
set _lastname=%2
IF "%_lastname%" == "" goto skip
set _folder=%_lastname%, %_firstname%
IF NOT EXIST "%_folder%" mkdir "%_folder%"
copy %_file% "%_folder%\WA4 - %_folder%.txt"
xcopy /Y "%_file:~0,-4%*.prt" "%_folder%\WA4 - %_folder%.prt"
:skip
Unfortunately, "copy" cannot handle wildcards like xcopy
Thanks!
-Ken
