3 versus 4 fins on maneuvering rockets / missiles.
Mon Oct 07 2019, 10:02PM
Registered Member #2431
Is there a reason 4 fins seem to be more common than 3 fins on missiles and controlled rockets ?
Obviously there's the surface area restoring force difference in surface area (3 vs 4) in just a ballistic non-maneuvering child's rocket. But is there a stability advantage or is it just a stowage-volume issue before its thrown at the enemy.
The NASA X-31 test program included the conclusions that 3 vs 4 thrust paddles seem to make little difference.
Thrust vectored aided Rockwell-MBB X-31
2Spoons
Registered Member #2939
Probably just easier to control - 2 fins for pitch and 2 for yaw
Plasma
Registered Member #61406
Center of pressure, its for stable flight, will add more later
