  • Guests: 28
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Turbine vs Piston Thermodynamics
Wed Dec 04 2019, 02:34AM Print
In my time working on turbine aircraft both hobby and military (5k$-120k$ engines) between 5 to 82 lbs of thrust at 300 mph or less i get a fuzzy feeling in my gut. A feeling that magically shrinking a 111 inch diameter GEnx turbine (58k lbs thrust) down to 4 inch diameter (82 lbs thrust), doesn't allow the expected linear decrease in thrust per volume, per unit of mass or per specific fuel consumption.
So considering natural scaling laws make that kind of comparison useless, I ask if the Brayton cycle describes this difference.
Further more if we compare a tiny turbine using the brayton cycle (not otto) to a mid-sized piston engine, would we find a region on the graph where their power and efficiency start to overlap ?
Sorry if this is a messy question Im not good at thermodynamics.
2Spoons
Wed Dec 04 2019, 04:44AM
your answer is on the first page
I think the other thing you need to consider is that viscous effects have a bigger impact as you reduce size. And you are probably aware that thrust is not directly related to energy ( M.dV vs M.(dV)^2)
Wed Dec 04 2019, 04:54AM
ok thats pretty complicated, but im reading it...
2Spoons
Wed Dec 04 2019, 04:55AM
Short answer : the efficiency of the Otto and Brayton cycles are the same, but Otto is best for a reciprocating engine and Brayton is better suited to continuous flow engines
Sun Dec 15 2019, 06:44AM
do the tips of the rotating turbine blades in the combustion section exceed the local speed of sound while surrounded by flame ?
2Spoons
Sun Dec 15 2019, 07:51PM
I wouldn't think so - you'd end up with shockwaves which I would have thought to be detrimental to an engine.
Sun Dec 15 2019, 11:09PM
i found this . . . and wsa looking at the pressure and velocity part of the turbine section. 150 psi @ 1400 ft/s
2Spoons
Mon Dec 16 2019, 04:19AM
Turns out speed of sound in a gas is only dependent on temperature (which I didn't know).
In the turbine section, with temps of 1090C(2000F) speed of sound is 740m/s (2400ft/s.)
Plasma
Mon Dec 16 2019, 05:38AM
Plasma Registered Member #61406 Joined: Thu Jan 05 2017, 11:31PM
Its also got to do with the chemical make up, H2,CO2,CH4 all have different numbers. The pressure is related to mocules by temperature.
They get close to the speed of sound with winglet's and taper.
If you can design a combustion chamber to handle large pressure differences and still work, worth aiming for.
Mon Dec 16 2019, 06:33AM
Plasma wrote ...
I think the rotary engine holds promise for 500-750 lbs class drones. I was thinking of conventional propellers with the tips cut off running in a tube (i.e. f-16 ish inhaling)
