3 versus 4 fins on maneuvering rockets / missiles.
Patrick, Mon Oct 07 2019, 10:02PM
Is there a reason 4 fins seem to be more common than 3 fins on missiles and controlled rockets ?
Obviously there's the surface area restoring force difference in surface area (3 vs 4) in just a ballistic non-maneuvering child's rocket.
But is there a stability advantage or is it just a stowage-volume issue before its thrown at the enemy.
The NASA X-31 test program included the conclusions that 3 vs 4 thrust paddles seem to make little difference.
Thrust vectored aided
Rockwell-MBB X-31 Re: 3 versus 4 fins on maneuvering rockets / missiles.
2Spoons, Tue Oct 08 2019, 12:33AM
Probably just easier to control - 2 fins for pitch and 2 for yaw
Plasma, Tue Oct 08 2019, 07:08AM
Center of pressure, its for stable flight, will add more later
