  • Guests: 18
Alfons (36)
Coronafix (51)
AmonRa (44)
05/09 Alfons (36)
05/09 Coronafix (51)
05/09 AmonRa (44)
Maximum Permissible RF Exposure FCC Regulations
Carbon_Rod
Tue Feb 12 2019, 05:24AM Print
Does anyone know the specific model the IEEE and FCC guidelines are based on?
For example, if I have a isotropic emission from my phone's WiFi, does the safety limits supersede normal regulatory guidelines.
The phone section:
17dBm at 2450 MHz we get roughly Pt = 50mW into the antenna
Antenna is a Gt= +-1dB gain matched 3.2mm * 1.6mm * 1.3mm ceramic style chip
This chart says 1mW/cm*2 in uncontrolled settings:
Given:
wavelength of about L=0.12m
distance from human skin to antenna of R=0.05m
assumed skin is around Gr = 0bBi
And used the ideal calculator from here:
Max Received power Pw = (Pt*Gt*Gr*L^2)/((4*Pi*R)^2)
Pw=0.0023 Watts (or 3.6dBm)
thus, a little over double the safety limits...
Now if I increase distance R >= 0.077m
Pw
Carbon_Rod
Tue Feb 12 2019, 05:33AM
part 2, as unable to edit my own post... :/
Now if I increased distance R=0.077m
Pw=0.001 Watts (or = 0dBm)
Or seems to fall within the safety margins...
If I used a Planar Inverted-F antenna, than near field behavior is unlikely isotropic making it even more ambiguous.
Any corrections in my approach would be welcome, as it has been awhile since I encountered the problem.
Cheers,
Rod
johnf
Tue Feb 12 2019, 06:21AM
Yep the phone companies know this this is why the inband limit for phones is much higher as they think you are only going to be on it less than 15 minutes per day.
do not stand near one of those masts with the panel antennas for cell big sites are up in the multi kW with all carriers on at once
Plasma
Tue Feb 12 2019, 07:14AM
Plasma Registered Member #61406 Joined: Thu Jan 05 2017, 11:31PM
Convert dBm to dBi, every 3 dBi you double the distance, work function type things, might not be ionized, its still not enough to release alpha,gamma,xray or beta, so cancer is out, maybe eyes and head have extra heat that will need to be protected from.
Uspring
Tue Feb 12 2019, 10:55AM
I don't think you can use the Friis equation to calculate a power density mentioned in the FCC regulation. The Friis equation tells you something about the total power received by an antenna and uses an effective receiving aperture (see Step 4 in the derivation). The power density is given by Step 2.
For an isotropically radiating antenna Gt=1 and the power density is simply the total power Pt divided by the sphere surface 4*pi*R^2, i.e. 50mW/314cm^2 = 0.16mW/cm^2. That's at a distance of 5cm.
Generally antennas don't radiate isotropically, though, a better approxiamtion is a dipole field. That depends much on the type of antenna. Also the near field (R less or around lambda) of the antenna is stronger than the radiative field, so one should account for this too. That's more complicated and has to include interactions of skin and flesh with the antenna near field.
Tue Feb 12 2019, 02:25PM
completely anecdotal ...
a friend and colleague of mine used to service and repair equipment in an amateur radio shop,
when amateurs go 'silent key' the family often sell equipment to the shop, and my friend could recognise who's equipment it was as he knew most amateurs in the area.
Talking to relatives he discovered that at least two 2m (typ. 5W@145MHz) walkie-talkie users had cancer in the right side of the head !
Neither of us use handheld transmitters (including cellphones) near our bodies, and especially not near our heads.
I did a little research some years ago;
I believe that ionisation is unlikely,
thermal damage is likely at high power densities,
and MITOSIS can be affected by surprisingly small electric fields.
To add to the confusion, I just found this article Link2
