  • Guests: 16
Alfons (36)
Coronafix (51)
AmonRa (44)
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Making a Geiger-Müller Counter
1 2 3 4  last
Sun Jul 22 2007, 12:47PM Print
I plan on making a Geiger counter so I can sense x-ray leakage from my future x-ray setup. I have a few questions about the tubes though. I've sighted out two different tubes, the STS5 and the FHZ74V. I've found very little information on them besides pictures. First of all which would be best suited for detecting x-rays/gamma rays? I assume both will work, but it seems that some tubes are made for alpha and others for beta radiation. Shouldn't x-rays be capable of exciting any tube?
Info on the FHZ74V.
I found nothing on the STS5, besides a picture from the seller's webshop.
1185107856 95 FT0 Sts5
Sun Jul 22 2007, 01:59PM
The tube in bottom photo looks like the SBM-20 in my russian GM counter
perfect for x-rays.
Is it worth making a GM counter when they're so cheap on eBay?
c4r0
Sun Jul 22 2007, 03:09PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
Yes, it's SBM-20 or similar on the second photo and it's good for x-rays detecting. You just need about 400VDC to power it. Number of pulses in 40s measure time is equal to radiation "power" in uR/h (1uR/h = 0.01uSv/h). You sholud get about 15 pulses (in 40s time) from natural background radiation. If you want I can send you schematics of a few russian geiger counters using this tube smile
Sun Jul 22 2007, 03:35PM
That would be great c4r0. cheesey
I can't find any cheap Geiger counters on ebay atm, and I can buy the GM tube from the same place as the HV rectifiers which I'll use for x-ray tubes. What I save in shipping costs will make up for it.
c4r0
Sun Jul 22 2007, 04:01PM
Ok, so this is the simplest and the most useful one - russian dosimeter BELLA:
1185119616 151 FT28803 Bella
It simply counts the pulses and displays it. Uses one SBM-20 tube
This one is more complicated - also russian POLARON-PRIPYAT: 1185119616 151 FT28803 Pripyat2
Uses two SBM-20 tubes.
And here is an old (1960s) Polish Army radiometer DP-66: 1185119616 151 FT28803 Dp66
It has three diferent tubes becouse of wide measure range (0,5mR/h - 200R/h), one of the tubes is SBM-20.
Also these websites should help you:
Sun Jul 22 2007, 04:30PM
Tube specifications
]1185121847_162_FT28803_sbm20.pdf[/file]
Sun Jul 22 2007, 05:13PM
Wow, thanks guys. I'll order a SBM-20 then, and tell how the counter turns out.
Simon
Mon Jul 23 2007, 12:34AM
Uzzors wrote ...
GM tubes are often not so sensitive to gamma and X rays but it should work.
Fri Aug 17 2007, 07:50PM
Well, he was all out of SBM-20s so I had to buy a FHZ74. I put together a simple circuit which provides a regulated output, and pops a speaker when the output is grounded (tube ionization). This gives the cool crackling sound familiar from games and movies.
1187377776 95 FT28803 Geiger Counter Schematic
Anyway, it's not acting like I expected it to, which is somewhere around 15 pops per 40 seconds.With the tube voltage set to 575V I get constant crackling, as though I were in the middle of Chernobyl. If I set the tube voltage down to 420V the crackling stops altogether. I don't even get occasional pops from background radiation. Is this normal behavior? I haven't tried the counter near a known radioactive source yet, maybe the counting starts again or increases even more. I'm not sure what the different voltages in the datasheet are for, but "arbeitsspannung" (working-voltage) must be what I need to drive the tube at. Will the tube only function properly at the working voltage, close to 500V? Or is the excessive crackling due to the circuit design?
]FHZ74.pdf[/file]
Fri Aug 17 2007, 09:21PM
I'm not sure but I think that your GM tube is for high radiation environments
50 r/hr is high (500 r over 5 hours is lethal according to wikipedia)
and I think the spec. gives 0 to 5 impulses per minute for background radiation
much less than the SBM20.
The constant crackling at 525 V is due to over-voltage breakdown in the tube (bad)
420 V should be good though.
Hopefully someone can give a second opinion?
1 2 3 4  last
